HAVE 1982 Z28 CAMARO WITH 1989 IROC Z 350 5.1 ENGINE
Old Feb 26, 2008 | 05:24 PM
camaro_tim81's Avatar
Car: z28
Engine: 402 Big Block
Transmission: th350
When I try to start I have to use starting fluid. Once started; will stay started and crank with key. Once off and left awhile; I try to restart with key and will not start. In order to start I need to reuse starting fluid in order to restart. It's getting spark and getting gas. Please help and let me know what could be the problem.
Old Feb 26, 2008 | 05:34 PM
Re: HAVE 1982 Z28 CAMARO WITH 1989 IROC Z 350 5.1 ENGINE
getting gas
One of these things is not like the other.
Either it's not getting ENOUGH gas, or the gas that's in the tank, is no longer flammable (a few years old or more).
I'm guessing this didn't just pop up out of a vacuum, like you were driving down the road and out of the clear blue it just suddenly up and became like this. Any history to it? Very recent motor swap perhaps? Has it EVER run since that motor has been in it?
Old Feb 26, 2008 | 05:39 PM
Car: z28
Transmission: th350
i bout it like this i olny had it fo like a week
i dont know any thing about it
Last edited by camaro_tim81; Feb 26, 2008 at 05:44 PM. Reason: Automerged Doublepost
Old Feb 26, 2008 | 06:05 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Check your fuel pump relay. The fuel pump may not be running until it builds oil pressure.
Check your fuel pressure.
Old Feb 26, 2008 | 06:17 PM
tekkitan's Avatar
Car: 87 IROC-Z
Also, if it is a 350 engine, you have a 5.7L. Just so you know.
Do the above and hopefully you will find your problem.
Old Feb 26, 2008 | 06:26 PM
Probably not the FP relay, since it "has gas". If it has a relay, which would be, if it has an electric pump.
Could easily be the pump however, if it's an in-tank pump.
It'd be helpful to know what induction the car had; either "crossfire" injection (TBI), or carb.
Old Feb 27, 2008 | 12:03 PM
Car: z28
Transmission: th350
my car is fuel injection
Old Feb 27, 2008 | 01:16 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
TPI or TBI? there's more than one type of EFI.
Old Feb 27, 2008 | 02:26 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
[quote=sofakingdom;3655839]Probably not the FP relay, since it "has gas". If it has a relay, which would be, if it has an electric pump.
quote]
I have a 90 and the oil-pressure sender acts just like a fuel-pump relay bypass. When there is sufficient oil pressure, the fuel pump is supplied power from the oil pressure sender. This can mask a bad relay since the car will start once oil pressure builds allowing the fuel pump to run.
Old Feb 27, 2008 | 04:18 PM
Car: z28
Transmission: th350
Is there a fuel pressure regulator? Mine is a TPI.
Old Feb 28, 2008 | 09:32 AM
IROCWPB's Avatar
Engine: 383ci TPI
Axle/Gears: stock
Your fuel pressure regulator is at the rear of your passenger side fuel rail. It's a round thing and should have a vacuum line running to it.
84z96L31vortec
Aug 20, 2017 12:16 AM
The_Phoenix
Sep 3, 2015 10:56 PM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
