uh oh oil pressure is high
Old Feb 27, 2008 | 08:20 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Ok so I made a video of my car last week and someone posted a comment saying "why is your oil pressure so high" I looked and finally saw it for my self. To get to the point what is the problem. Thanks
http://youtube.com/watch?v=TB_Uztb7IT4
Old Feb 27, 2008 | 08:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: uh oh oil pressure is high
60psi on a cold engine isn't high. not to mention it's a crappy factory guage and sender. hook it up to a mechanical guage and you'll see. what oil are you running also?
Old Feb 27, 2008 | 08:44 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
when it is cold out and you said you had just started it up they will always read higher till the engine is fully warmed up, mine and wuite a few other ppl i know have the same issue, once it warms up they will drop to about 30-40 psi. mine is a different story.since i have a 355 decently built with a high volume oil pump when mine is cold it has 75 psi at idle then once it warms up its 45-50. so i dont think you have anything to worry about
Old Feb 27, 2008 | 08:53 PM
Transmission: 700r
ok because I just got the car and didnt want it to have problems starting already and I dont know what oil is in it because I just bought it but I would say 10w-30
Old Feb 27, 2008 | 09:06 PM
most likely
Old Feb 28, 2008 | 09:30 AM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
Yeah, whoever made the comment obviously didn't bother to look at your temp sensor, completely normal.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
