knock??need help.
Old Feb 28, 2008 | 04:06 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
knock??need help.
i have some kinda knock at 1500 to 3000 but smooth out over 3000. has no lose in power. what could be causing this? i do have roller rocker. could that be causing the nosie?
Old Feb 28, 2008 | 08:07 PM
intex1982's Avatar
Re: knock??need help.
anyone?
Old Mar 3, 2008 | 06:37 PM
intex1982's Avatar
ok changed oil no matel in it or anything. motor only does it when it hot. used a hose to pin point it and a scope thing. cant pin point it. after running it hard dont get any worse. so any ideas?
Old Mar 4, 2008 | 12:45 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Loose flexplate or torque converter bolts.
Old Mar 4, 2008 | 11:18 AM
intex1982's Avatar
also has 30 psi oil in gear warm and driving 55 psi warm. checked flexplate and no cracks. but my torque convert aint all the way to the flexplate its pressing on the starter ring.
Old Mar 4, 2008 | 07:35 PM
five7kid's Avatar
Sounds like you know what you've got to fix.
Old Mar 4, 2008 | 08:54 PM
intex1982's Avatar
i fixed that didnt help. but this nosie i find by mistake. no telling how long its made this nosie. just one day i told my gf to get in the car and turn it up 2500 rpm and heard it. i was checking something else. but cant hear it going down the road. just if ur under the hood giving it gas. anyone have anymore idea?
Old Mar 4, 2008 | 11:25 PM
five7kid's Avatar
That sounds present tense to me.
Did you fix that?
Old Mar 5, 2008 | 05:57 PM
intex1982's Avatar
Did you fix that?
yes i did.
Old Mar 5, 2008 | 11:17 PM
five7kid's Avatar
Sure sounds like something associated with the crank. The sound seems to come from everywhere and nowhere.
What are you using for a damper on the front? How did you check the flexplate for cracks? Are you sure your flexplate to crank bolts are tight? (that one bit me last year)
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Numbah-1
Oct 2, 2015 08:27 AM
efiguy
Sep 27, 2015 01:30 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
