Burning oil and hard oil deposits on plugs
Car: 83 Z28 modified 350
I need some opinions on what to do here. I have a 355 w/488 lift cam, flat top pistons,882 heads ported/polished 202-160 valves, professional prod intake, headers, edelbrock 600. Motor only has about 5000 miles on it and I've went through 2 sets of plugs. Got an oil leak (chrome pans suck) but think I'm burning alot more than I'm leaking. By the plugs I'm leaking oil into cylinders, but dont know whether its from heads or rings didnt seat. I've got new heads...procomp aluminum heads to put on but not sure whether to go ahead and pull motor to check rings as well or just swap heads for now. How can I determine if its leaking past heads or rings didnt seat. I cant believe that 5 or 6 of the pistons rings didnt seat right but thats what I'm wanting info on. Was gonna swap new heads this week but thought I'd get some feedback from the more experienced.
Re: Burning oil and hard oil deposits on plugs
882 heads
488 lift cam
Since you've got a set of heads, that'd be the first best thing to do, even if the 882s were working perfectly and weren't suspects. It'd be a good idea to get a better cam too while you're at it, it'll never be any easier to swap it than during a head swap. Last edited by sofakingdom; Mar 3, 2008 at 07:43 AM.
Ok, how can I tell if I'm having intake sealing issues without just replacing it? That is not the camshaft I have. I dont know what the brand is, I cant remember for the life of me, all I have is the specs I tore off the box. They are:
Cam Specs Int Exh
Dur@,050 224 234
Valve lift .465 .488
Lobe Sep 107 117
Lash hot HYD
L=22 = 06
Pistons are speedpro Hyp flat top
Cam Specs Int Exh
Dur@,050 224 234
Lobe Sep 107 117
Lash hot HYD
L=22 = 06
http://store.summitracing.com/partde...art=SUM%2D1105
Next one down in the same series as the one I posted before. Still, not a very good cam... very old design, very slow lazy lobes; makes OK power for its duration and lift, but far from what a more modern cam would do. Those were designed back in the late 60s when all the valve springs you could get were either stock, or Vasco-Jet all-out racing ones. Nothing in between. That series of cams was intended to be "compatible with" stock springs. So they're pretty ... non-aggressive, to say the least. You get either a HUGE dose of the "big cam" problems, for any given level of power; or, conversely, for any given level of "big cam" misbeahvior you're willing to tolerate, FAR LESS power.
If your other heads are 64cc, then just that ONE change, will raise your CR from 8.3:1 to about 9.3:1. MUCH MUCH better.
If the pistons came up to the stock deck height (.025" give or take), your CR would be 9.7:1, and if the block was zero-decked, it would be 10.3:1.
I'd suggest a Comp XE268 cam, or the Lunati Voodoo 60102 or 60103.
Go ahead and change your heads.
Regardless of whether it's the oil burning source or not, it's the source of ALOT of lost potential horsepower. I STRONGLY recommend putting a better cam in it at the same time. Take a good look at everything while you have it apart, and see if you can spot where the oil consumption is coming from. I'd almost bet money that one way or another, the heads are the source of it, if it's not the intake gasket surface. Last edited by sofakingdom; Mar 3, 2008 at 09:53 AM.
Is there any way I can tell if it is the intake or not? What should I look for when I take the intake off? Thanks for the advice I appreciate it all.
look at the gasket. See if it's torn, or if it's in place and properly compressed, or what.
You might even find that the gasket doesn't line up with either the intake ports, or the head ports, or both. Depending on what gasket you used.
Ok great, well that gives me something to look for then. I think instead of pulling the motor and tearing it all back down I will just do a head swap and see how that goes. As far as the cam, the machinist that does all my machine work and I get all my parts from recommended this cam. I cant believe that its that poor of a cam, not doubting you, just wondering if its the same one your thinking of. Good vacuum and streetability, yet has a decent lope at idle. I dont know much about cams thats why I listen to him and his suggestions. He knew I was going to be getting these alum heads at later point and said this would be a great match. Again thanks for your input.
That cam is one of those "old standby" type of things. It's an old generic grind that's been around for 35 years that I know of. Not "bad", just nothing special, modern, state-of-the-art, or competitive.
There's a whole series of them. Originally, they were sized for 300 (283, 260, 289, 318), 350 (327, 326, 350, 340, 351, 360), 400 (383, 389, 400, 403), and 450 (428, 455, 440). They're 204/214 @ .050" (the "RV cam"), 214/224 (the "mild cam"), 224/234 (the one you have), and 234/244 (the "RPM" cam). Note that Edelbrock uses at least 2 of them in their "power package" kits; the 204/214 is the "Performer", and the 234/244 is the "Performer RPM". They used to have a 3rd that was in the "Torker" package, might still for all I know, which I think is the one you have. Note also, that those cams have been around DECADES longer than those castings they're supposedly "matched" to go with. So much for the concept of "matched", designed for", etc.
They're not "bad" cams, by any means. Just like, wood stoves aren't "bad" to heat your house with, either. It's just, we've learned a thing or 2, as a species, since those things were invented. We can do better than that now.
Since they came out, fuel has changed, cars have changed, markeptplace expectations have changed, speed limits have changed, laws have changed, design techniques have changed, the competition has changed, .... but those cams are the same they've been for a LONG LONG time.
Look at the specs on the Summit cam, compare them to yours. Look on Edelbrock's site and get the specs they give there. Look at AMotion, Melling, and dozens of other suppliers that sell them. All the same thing.
Since they came out, fuel has changed, cars have changed, markeptplace expectations have changed, speed limits have changed, laws have changed, design techniques have changed, the competition has changed, .... but those cams are the same they've been for a LONG LONG time.Look at the specs on the Summit cam, compare them to yours. Look on Edelbrock's site and get the specs they give there. Look at AMotion, Melling, and dozens of other suppliers that sell them. All the same thing.
Point well made and well taken lol. I will definately consider changing cams, if I do that do I also need to go with new lifters even though these only have about 5000 miles on them?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I know i'm late but...
Yes you need new lifters. Flat tappets always need to be replaced.
That sucks, you fell into the common trap of hot rodding. That parts list there is a VERY common one. Lots of magazine hype about it. Not a lot of HP behind it though
Low compression, decently big cam, etc.
I think snagging some 416 heads, do some port work and throw them on. That alone (with bigger valves) will jump up your CR to the "fun" spot. It's a cheap solution. Aftermarket 64cc heads would also be great, if you can spare the cash. The voodoo 60103 is a solid winner in that combo as well. You'll probably find you want to do some port cleanup work on that intake too
Ya I already got the procomp alum heads 64 cc. Gonna do the swap sometime within next week hopefully. My main concern and hope is that the heads is where I'm leaking oil into my cylinders and not that my rings didnt seat. But I cant imagine that I'm having seating problems with most of my cylinders.
Car: 1982 Trans-Am
I agree.
Once you swap the parts over, drive the dogs ***** off it. Help seat the rings as much as possible
eightsixseven
Dec 16, 2024 01:50 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
