oil leak, cant find it
Old Mar 8, 2008 | 10:49 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
im about rdy to burn this sumbitch........got it running good today.....adjusted the carb and timed with a light........runs great, looked under it to adjust the shifter linkage and ill be darned if they wasnt a puddle of oil as big as a great dane on the floor......it makes no sense because its all on the bottom of the headers, but the bottom of the oil pan is dry......first i thought it was a rear main....its dry..............i did see a little oil on the bottom side of the plugs what time i was under it, maybe the valve cover is leaking and the headers are buring the oil off top but
not hot enough to burn the bottom clean.................anybody have any ideas?
Old Mar 9, 2008 | 09:36 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: oil leak, cant find it
Could it have come from the dipstick? Not having good crankcase ventilation can cause the engine to push oil out of the dipstick tube. You didn't just add a nifty new air cleaner did you?
Old Mar 9, 2008 | 09:38 AM
This bolt hole goes into the fuel pump rod passage. Is there a bolt in it? If not, put a short one in, with a drop of sealer on the threads.
Old Mar 10, 2008 | 11:34 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
the bottom under where the fuel pump bolts up?
Old Mar 10, 2008 | 11:50 AM
The one with the circle around it in the pic.
I wouldn't describe it that way, but you might. Doesn't too much matter what you call it though, as long as it has a SHORT bolt in it with some sealer on the threads.
Old Mar 10, 2008 | 08:26 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
i took the oil pan off today.....the guy who built my engine forgot to use the rubber seal that goes on the back where the pan curves to cover the crank
Old Mar 10, 2008 | 09:24 PM
Nsomnia's Avatar
Doh!
Old Mar 11, 2008 | 09:43 AM
Wow....
I think I'd be having a hard time sleeping at night wondering what else this person "forgot"....
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
MY87LT
Aug 17, 2015 08:43 AM
bamaboy0323
Aug 15, 2015 07:20 AM
drathaar907
Aug 6, 2015 04:20 PM
