350 how much $$$
Old Mar 11, 2008 | 09:03 AM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
350 how much $$$
I want to swap my 305tbi to 350 carbed. I want to be runnin between 350-400 hp. how would you guys do this.
Get it from a junkyard or get from jegs?
I am 17 dont have a hole lot of money want to do this as cheap as posible!
thanks
kevin
Old Mar 11, 2008 | 02:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well, we all want to do it for the least money, but not having a whole lot is a problem.
What would I do? Get a running 350 engine, shortblock if necessary, that doesn't need a rebuild ($150-$300). I'd get an upgraded Vortec head kit from sdparts.com that includes Vortec heads upgraded for more lift, Performer RPM intake manifold, rockers, gaskets, and bolts (about $1100 plus shipping). To that I'd add a Comp XE274 cam (roller version if the 350 block is roller - $150-$250), Holley 650-750 CFM double pumper carb ($400 new), and full exhaust (that alone will run you a good $700 for a decent system). That'll put you easily over 350 HP, and probably close to 400. Little things will probably run you another $200-$300.
Of course, your tranny will no longer be happy with you.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
