am i ****ed
Old Mar 24, 2008 | 12:00 AM
RicksIroc86's Avatar
Car: 84 camaro z28
am i ****ed
hey
my car has been running like **** lately so ive been tuning it up(pcv valve,air filter, oil and oil filter,cap rotor and coil, knock sensor, etc etc etc)
so i went to change the spark plugs today started pulling em out and noticed that they all had a bunch of oil on em
i asked my dad about it and he said im probly ****ed and should have the engine rebuilt.
so my question , is this a really big problem
Old Mar 24, 2008 | 12:04 AM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: am i ****ed
sounds like blow by in the cylinders which means your oil rings may have gone bad.. how many miles are on the engine?
Old Mar 24, 2008 | 12:09 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: am i ****ed
Did you have it sitting for any time? Do you see smoke coming out the back when you're on the road? Are all of you're plugs wet? Might just be valve guides and a valve job might fix it.
Old Mar 24, 2008 | 12:10 AM
Car: 84 camaro z28
Re: am i ****ed
it says there are 87000 miles but i think it rolled over because everything seems to be going bad
and idk if it was sitting before i got it but yea it was blowing out smoke but then i changed the o2 sensor so it doesnt do it at all times but itll blow some smoke out when i get on it but not horribly tho
Old Mar 24, 2008 | 12:16 AM
Kevin84Z28's Avatar
Re: am i ****ed
Well, it doesn't sound like anything is broken, just worn out.
Old Mar 24, 2008 | 12:18 AM
Car: 84 camaro z28
Re: am i ****ed
ok thanks, i have another question
sometimes ill turn on my car when its cold and itll start up and about 10 seconds later ill just hit the gas pedal a little and it wont rev or anything it just dies completely in like 1 second, and then ill start it again and itll run OK, anything you know of that it could be?
thanks
Old Mar 24, 2008 | 12:20 AM
Car: 84 camaro z28
Re: am i ****ed
i was thinking maybe something to do twith the egr system possibly
btw its a 305 tpi
Old Mar 24, 2008 | 12:22 AM
Kevin84Z28's Avatar
Re: am i ****ed
sounds like a fuel problem. Do you have one of those clear plastic fuel filters on it?
Old Mar 24, 2008 | 12:23 AM
Car: 84 camaro z28
Re: am i ****ed
no i replaced it already and it was black and not see through
