Still Running Rich
Old Mar 29, 2008 | 08:45 PM
mouthforcombat's Avatar
Car: '86 Iroc Z
Still Running Rich
I have an '86 305 TPI. I recently put the top half of the motor back together with many new parts. Too make a long story short, my idle drops very low and sometimes stalls when braking, when the motor is warm. I just had the vacuum system completely redone with all new line and the car was put in time, according to spec... But the idle still drops and is goofy. I did have an 02 sensor welded in to the headers (on the driver side). It sits on only one tube (the second closest to the front of the car). Do you think that since it's not at the collector of the headers it is giving the computer a bad signal and causing my problems? If that's not it, the only other thing I can think of is maybe the distributor. Any ideas? Thanks in advance.
Old Mar 29, 2008 | 10:12 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
Re: Still Running Rich
check th tps sensor and make sure its between .54 and .56 volts
Old Mar 30, 2008 | 03:06 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Not a good Idea to sense only the exhaust from one cylinder, the ecm will feed fuel to all cylinders based on that one cylinder.
I can't say that what solved my idle problems will solve yours, but mime vanished when I installed a heated O2 in my SLP headers.
Old Mar 30, 2008 | 07:27 AM
Car: '86 Iroc Z
Thank you both very much. Where could I buy a "heated" 02 sensor?
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
