Tpi swap onto lg4 base?
Old Mar 31, 2008 | 09:19 PM
Thatguy's Avatar
Car: 1985 Trans Am -Ws6
Engine: 305 Tpi
Transmission: 700 R4
After browsing through the boards i came to wonder what a tpi intake setup would do on a lg4 base with the dished pistons(8.5 comp) gay cam ect. . I imagine it would prolly suck power wise and be a waste of time due to all the work. But i currently have both the Lb9 isnt running atm but the other is. F/i on my ghetto ride($150 83 firebird) would be funny and give me something to do while i search for a low priced l98 or lt1 for my T/a .
Old Mar 31, 2008 | 10:15 PM
ljnowell's Avatar
Re: Tpi swap onto lg4 base?
The quality of the head is basically the same. I guess the 86 tpi would have had 416s, right? Anyway, you would lose some compression and the cam sucks. If you are going as far as the intake though, score yourself a good used lt1 cam, and stick it in at the same time. I imagine it would run as good as a lb9.
Old Mar 31, 2008 | 10:52 PM
Thatguy's Avatar
Engine: 305 Tpi
Prty much figured all that. Not sure on the Lt1 cam though havent priced one out money is VERY limited. but if i could get one cheap i might just borrow the exhaust frm the TPI and stick with the old holley carb the pervious owner stuck on there. Dont know really just lookin for mods that i can actually do while i search for another job.
Old Apr 1, 2008 | 12:18 AM
ljnowell's Avatar
LT1 cams go for between 25 and 40 dollars on ebay.
Old Apr 1, 2008 | 01:12 AM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
his LG-4 should be a flat tappet cam ... right? So a LT-1 wont work. Just find a L-69 profile ... If your LG-4 is a 87 block didn't they have flatops and have 9.5 compression anyways and a roller cam? Or is this a early LG-4?
Old Apr 1, 2008 | 10:16 AM
ljnowell's Avatar
I didnt think about that, it could be a flat tappet.
Old Apr 1, 2008 | 08:18 PM
Thatguy's Avatar
Engine: 305 Tpi
Its an 80-85 block so its flat tappet. Guess ill look for a l69 cam then lol. Thanks for the advice im glad i didnt get flamed since there are like a million make my Lg4 better posts.
Old Apr 1, 2008 | 11:16 PM
ljnowell's Avatar
I dont think i would go for a l69 cam, i would look for something a little better. Since its flat tappet, best to use a new cam. You can reuse a flat tappet with new lifters, or with the originals if they are kept in order with the cam lobes. But, IMO, its not worth. Maybe look at the comp cams xe series, like the most mild? l
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
