How can I get some cheap ponys?
Im looking for some extremely cheap ways to give my 1982 Trans Am 305 H.O. Carbureted Motor some more ponys any ideas....
I already have a Bigger Cam and a Stall Speed....
This is my dads new 82' not my Kitt car.
If you could help me out I would appreciate it.
- Thankyou Nic! -
- Thankyou Nic! -
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: How can I get some cheap ponys?
NOS, carb, remove any emissions and un-needed things
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
for about $300 - $500. you could stick in a 350 engine from the yard or something like that. and you have instant power gain.
and spend another $500 and you have even more power.
thats what im in the process of right now
but i think nos is the cheapest way to get alot of power out of the engine.
also get new upgraded exhaust. headers and bigger pipe.
and you could free up some lbs from the car by removing any unwanted lbs. that could help bit.
K the car is already about 350 lbs lighter it's got lighter hood and front end, was shaved and that's it so far what else should I do for weight reduction alluminum everything or what?
Engine: engineless
alum. parts will help. like the cyl heads, intake, water pump. the radatior, heck if you have alot of money even an alum. engine block.
alum will help with lighting things up. roating parts or any part that moves can be changed to alum. that will lighten and give you some extra hp as well.
like the drive shaft. wheels, light wight pistons, Connecting rods.
you could get some underdrive pullies.
you can buy one of there twin turbo packages from ebay that sell for $899.
im not to sure how well they will work or how the quality of there parts are but im sure they will work for the time being and you can slowly upgrade the parts to. like different turbos, and the turbo headers and stuff like that.
or you can just get a Nos kit for afew 100 bucks.
but getting the exhaust work is probably help you the most right now and then you can add up parts and youll probably notice the power alot more to inted of having the small exhaust.
i believe the ehxuast on the 305 is. 2.25" or so? thats what it was on my car at least. upgrading to a 3" is probably a good idea.
Damon
Sep 26, 2015 04:29 PM
