Serpentine Belt Guys
Old Apr 8, 2008 | 04:09 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Does the AC brace go from the rear of the compressor to the third manifold stud?
JamesC
Old Apr 8, 2008 | 04:16 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Re: Serpentine Belt Guys
I don't believe so. The bottom bolt for the A/C compressor actually has the head of the bolt facing the cylinder head and is like a 1" stubby bolt. The bolt that goes into the block is the top bolt for the smog pump or delete pulley.
Eric
Old Apr 8, 2008 | 05:25 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
James, if you are installing the GM serp kit then yes the brace bolts to the forward bolt hole of the #4 cyl using the longer of the spacers in the kit. The other side is attached to the stud toward the outside edge of the compressor. I have done this install using the "deluxe" kit. If you have any more ?'s, ask away
Old Apr 8, 2008 | 05:54 PM
JamesC's Avatar
Thanks, I appreciate your input. I am using the GM kit. The stud toward the outside edge of the bracket is supposed to be torqued to 37 lb. ft. Does that bottom the stud out on the front bracket?
JamesC
Old Apr 8, 2008 | 06:07 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
I have the stock serp setup on my 89 Formula. Is the new serp setup different than the one I have?
Old Apr 8, 2008 | 09:50 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
James, the stud should be installed so that 1-1/2 threads show on the front side. You are actually only torquing the nut on the back after installing that brace. Boss355, the GM aftermarket serp kits are basically stock components set up in a generic package. It also is designed to eliminate the AIR pump(for use on vehicles that never had one, uh-huh) replaced by an idler pulley and changes the belt routing from your stock pattern. hope this helps
Old Apr 9, 2008 | 05:17 AM
JamesC's Avatar
Excellent. Hopefully I button that portion up today (probably would have yesterday but I lost the spacer in the engine bay for 30 minutes or more) and get on with the install. Any chance, squirted, your car is carbed?
JamesC
Old Apr 9, 2008 | 08:53 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
for now I have a carb sitting up top but, have plans for HSR soon. What else could I hopefully help with?
Old Apr 10, 2008 | 05:55 AM
JamesC's Avatar
I have everything assembled (I falsely believed I'd cross threaded a bolt for a while), but I need to do some wiring which should go smoothly. I appreciate your help, squirted.
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
mustangdmurder
Aug 21, 2015 07:17 PM
Street Lethal
Aug 14, 2015 08:25 PM
jahblah
Aug 12, 2015 05:54 PM
