The Camaro isn't running right.
Old Apr 8, 2008 | 07:48 PM
yaretheytaken's Avatar
Car: 92 RS
Engine: 350 Carb'd (almost TPI)
Transmission: 700R4 (soon a T-5)
Axle/Gears: 3.23's
I started my car for the rist time after my rebuild today. It was running great for a while, then out of nowhere it started backfireing out of the carb. At first I thought I was running out of gas because I was on Empty, so I filled up. Still backfiring. I'm wondering if this could be due to my timing being too advanced. We do not have a timing light and we timed it by ear. I want to reiterate that it was running beautifully for 20-40 minutes before the problem started. Also, the Camaro smells like it is running rich. Thanks in advance.
Old Apr 8, 2008 | 08:23 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: The Camaro isn't running right.
Check your cam lobes.
Old Apr 8, 2008 | 08:47 PM
Car: 92 RS
Axle/Gears: 3.23's
I never messed with my cam. I didn't even take my timing chain off. I don't really understand how my cam timing would have been affected. If you could explain more I would appreciate it.
Old Apr 9, 2008 | 07:43 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
You said you rebuilt it, so I thought you had put a new cam in. Suddenly popping thru the carb can be the result of a flat exhaust lobe. But, if you didn't touch the cam then it should be ok.
Old Apr 9, 2008 | 07:50 AM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Could the distributor be loose,it may have moved while engine was running.
Old Apr 9, 2008 | 01:00 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Maybe timing chain jumped a tooth.
Old Apr 9, 2008 | 04:45 PM
Car: 92 RS
Axle/Gears: 3.23's
My first thought was maybe the distrubutor was still a little loose. I can't check it till Saturday though. I also notice an increase in rpm's. That would also indicate my timing being advanced, right?
Old Apr 14, 2008 | 05:59 PM
Car: 92 RS
Axle/Gears: 3.23's
So now my Camaro has developed a new problem, it won't start. It cranks and cranks and cranks, but it never starts. I'm getting plenty of fuel, in fact when I try to start it, it will backfire and spit fuel out of the carb. I also checked for spark and I am getting spark. Any input would be appreciated.
Old Apr 14, 2008 | 07:56 PM
bigj350's Avatar
Have you had the distributor out at all? I wonder if its a tooth off.
Old Apr 14, 2008 | 09:00 PM
Car: 92 RS
Axle/Gears: 3.23's
I have had the distributor out a few times. Every time I put it back in I made sure that #1 was at TDC. Any and all suggestions are appreciated.
Old Apr 16, 2008 | 01:05 PM
Car: 92 RS
Axle/Gears: 3.23's
I put #1 up again and my rotor was way off. So I took the distributor out and repositioned it so the rotor was pointing at #1. I then turned the key and it fired up, that was a great feeling. Now it is once again popping out of the carb. I have the car at my school now (community college auto. mech.) and all of my teachers and a few classmates seem to think that it is just off a tooth or two. Tomorrow I will try and get everything all lined up. Thank you everyone for all of your assistance.
Old Apr 16, 2008 | 06:34 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Do you have the correct gasket/spacer under the dizzy? Too thin and dizzy will turn.
Old Apr 17, 2008 | 01:23 PM
Car: 92 RS
Axle/Gears: 3.23's
Well, today we got the timing all lined up and started it and it ran fan at idle, but when I would give it gas it would still pop out of the carb. We let it idle for a few minutes and while it was idle we noticed a slight knock coming from the driver side valve cover. So, I pulled the valve cover off and one of the push rods came out from under the rocker arm. I also had a 2 other rockers that were a little loose. I dropped the ball on that one, must not have adjusted them properly. Oh well I'll learn from this one. Anyway though, I don't have school tomorrow, so the next time I will be able to work on it is Monday. The push rod that came loose was not bent and when we pushed on it it would set into the lifter. So on Monday I'm going to check out the passenger side and re-adjust all of them. I will let you all know how it works out on Monday.
Old Apr 17, 2008 | 01:29 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Well I'm gonna learn from your mistake too bro, thanks for posting this, I'm gonna pay a lot of attention when building my motor, there goes the 6 picks of bud around the garage idea lol.
Old Apr 17, 2008 | 02:39 PM
Car: 92 RS
Axle/Gears: 3.23's
I'm glad I can help others with my mistake. Take your time building don't rush through anything. Do it right the first time so you don't have to wait an extra month to drive your car.
Old Apr 17, 2008 | 03:42 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Don't feel too bad. The first time I installed a cam I picked it out myself. I was doing allot of reading and learning as I went along. I installed a new cam and went so far as to getting the intake bake on when I came to the conclusion that I had picked the wrong cam. Ripped it all back apart and put in a different cam. Wife thought I was nuts, but I made the right decision even though it took more time. Just glad I didn't have to drain and pull the radiator again.
Old Apr 17, 2008 | 11:03 PM
Car: 92 RS
Axle/Gears: 3.23's
Good thing you didn't install that radiator. Good to hear you figured it out before you got to far into it. I'm not too upset about it, I am human after all and I will make mistakes. I'm still learning and at least I messed up on my car and not a customer vehicle.
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
InfinityShade
Aug 22, 2015 08:00 PM
Fronzizzle
Aug 9, 2015 01:15 PM
