combo ?
Old Apr 9, 2008 | 08:43 PM
carscomefirst's Avatar
Car: 04 gtp, 96 f150, 88 camaro
Engine: 3.8sc, 5.0, 385ci
Transmission: auto, 5speed, 700r4
combo ?
Im building my car using parts left from my dirt track days.
I hope to get on the road this summer.
Basic use will be little street, little strip, little sitting at cruise ins
Short block:385 cu
350 2 bolt arp studs .040,
Sealed power hv oil pump,
Moroso oil restrictors,
Renagade 3.75 steel crankshaft,
Eagle 5.7 h beam floating pins
Speed pro H635cp40 ..200 dome coated pistons aprox. 12.4:1cr w/ 64 cc heads
ballanced rotating assy,
Renagade +.100 pushrods
Lunati 40145 solid flat tappet cam
Int:.552 lift 256 dur@.050 .024 lash
Exh:.519 lift 259 dur @.050 .030 lash
106 lobe seperation
installed straight up aprox range per lunati 3800-7000rpm,
dual idler gear drive of unknown origin.
Heads:
GM cast iron BowTie 2.02 intake 1.6 exh unported,
Manley undercut valves,
K-motion tool steel springs good to .600,
3/8 ARP studs w/ guide plates,
Crane 1.5 silver rollers,
Pro products stud girdle,
Pro products#52031 power+plus single plane manifold,
Holley 750 vacume secondary(only carb I have other than 2bbl)
Tranny:
local built 700r4 w acc2200-2800 converter#48442(I know too low but I got it for free)
Rear:
10 bolt 3:73 limited slip(still need to set up)
The motor ran strong on a 3/8 dirt track in 75 nova(3200lbs) w/ cast iron BowTie intake, stamped longslot rockers and a Duel jet carb
What are your thoughts, and how much power do you think I'll make.
Last edited by carscomefirst; Mar 12, 2010 at 08:29 PM. Reason: fat fingers on cam #40145 instead of 50145
Old Apr 10, 2008 | 12:06 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you sure about that cam info? The p/n doesn't match the type or specs.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
