i just want to drive my car
Old Apr 10, 2008 | 01:45 PM
los12's Avatar
i have a 91 rs with a 350 swap the car has turned over many times. its been in storage for the past 3 years i have started it before the last time was back in oct 07. now it was winterized, and everything put in a new battery. i took the tbi apart and cleaned it out in doing that i found its not priming nor injecting gas when i crank it, but if i put gas thru the carb it fires up like a champ then dies. my question is can this be a fuel pump problem, fuel filter,or relay? it never did this before first time it does that. if yall can help out id appreciate it.
Old Apr 10, 2008 | 02:23 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: i just want to drive my car
Welcome to TGO.
Can you hear the fuel pump activate?
Old Apr 10, 2008 | 02:24 PM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
if u put gas into the tbi or carb and it fired than its probley the fuel pump
Old Apr 10, 2008 | 02:33 PM
los12's Avatar
No I doesn't make a sound that was my first look but its a hassle to take that sucker out, don't want to do that yet is there a fuel relay or other place were there's fuses other than under the dash. Thank yall for answering so quickly
Old Apr 10, 2008 | 02:43 PM
Wadebryant's Avatar
The fuel pump relay is behind the drivers side kick panel. Pull the panel and the relay. Take the cover off of the relay. Inspect the contacts, looks like old distributor contact points. They may be bad or corrosion may have had it's way with it. Test it if you have an ohm meter.
Also check your fuel pump fuse. Located under the left side drivers side knee panel.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
kyleb24
Aug 15, 2015 08:24 AM
