where can i find an air cleaner to fit?
Old Apr 15, 2008 | 09:37 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Not wanting to run without an air cleaner, but they just wont clear my hood, any suggestions?
Old Apr 16, 2008 | 05:37 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: where can i find an air cleaner to fit?
Have you tried a drop base?
JamesC
Old Apr 16, 2008 | 08:17 AM
82Five-O's Avatar
Car: 82 Sport coupe
You mean like a holley base? where could i find one?
Old Apr 16, 2008 | 08:26 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Summit sells drop bases. Probably Jegs and any other mail order place. You can probably look up the company/part no. and call around and see if any local parts stores carry them as well. They are not uncommon.
Old Apr 16, 2008 | 10:30 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
if you're using a Edelbrock performer RPM hi rise manifold this is the air cleaner base you want.
A holley carb requires the choke air horn removed and the bowl vent tubes shortened.
Use a 14x3" filter and a common 14" air cleaner top
may require modifying the throttle linkage bracket and choke linkage.
Edelbrock carb requires a 5 1/8"x 1/2" air cleaner spacer to clear the banjo fuel fitting. Fits some Qjet carbs.
HEI distributor requires minor reshaping of the back of the base flange to clear the big distributor cap.
This is the lowest hugging, best flowing drop base air cleaner made.
Used on old Corvettes.
http://www.noahperformance.com/prodd...hp?prod=N2193B
Gives a full 1" extra hood clearance than the typical aftermarket drop base air cleaners do.
Old May 12, 2010 | 11:52 PM
gorski123's Avatar
This worked great for me when I had a regular Holley 4150 model carb. I recently purchased a Holley 750 street HP carb and this base dosen't seem to fit that at all. Has anyone else ran into this problem?
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
