engine crank and combo advice
Old Apr 16, 2008 | 11:57 AM
82 Indy Z's Avatar
Car: 1982 Indy 500 Pace Car Replica
Engine: Stroked 350 (385ci) TPIS Mini-Ram
Transmission: 6-speed
Axle/Gears: Stock w/Disks and 4.10's
Hey guys,
Looking for some engine tech advice for my rebuild. First I will layout my current combo:
350 4 bolt main block .040 over
400 stock crank
6" stock rods
SRP forged Pistons
SLP 51008 cam .509 lift
Canfield 23-500-65 heads
Mini-Ram TPIS Intake
SLP 1 3/4 headers
Fidanza Flywheel
I am looking to freshen up my motor and I want to internally balance my engine. My question is What could be the better Crank to have my engine internally balance with? I have looked at Eagle, Callies and Scat, and I am at a loss for the best value. I have been told that lighter weight is better for quicker reving, but is that as durable as a regular crank? Also, any advice on a cam would be appreciated
Motor will be used for autoX and some street/strip drag racing. I plan on keeping the car so durability and endurance is what I am looking for.
thanks in advance,
Old Apr 16, 2008 | 01:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: engine crank and combo advice
Nobody builds a 383 with a stock 400 crank anymore, and there are no 6" stock rods.
Old Apr 16, 2008 | 02:15 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Eagle makes some good forged kits that are already balanced. I can't find the cam specs, but from the look of the heads I don't think this will be for the street. If streetability isn't a concern I would try a larger cam... if it is, then smaller heads. AFR's have better low-mid. With a good solid roller, it would be possible to get 500hp out of the motor, but it would be hard on the street.
Old Apr 16, 2008 | 05:40 PM
82 Indy Z's Avatar
I built my engine about 8 years ago and got a stroker kit from VSI. I believe Wheeler was the MFG. Anyway it is a 400 crank with the journals cut to fit the 350 mains.
So if no one makes 6" rods anymore, who makes a stroker crank that will allow my to use my 6" rods? I am really looking to get a aftermarket crank that will not require much to internally balance the motor.
Is anyone familiar with the Callies magnum, dragonslayer, and compstar? Or the Scat ultralight cranks?
Just looking for some guidance,
Old Apr 16, 2008 | 08:02 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
of course you can reuse your 6 in. rods he only meant that your rods aren't stock
and any aftermarket crank designed to be internally balanced will work.... as to lighter... that depends on your school of thought and your wallet... any weight removed from the rotating assy. will produce quicker revs... however that lost weight will also decrease the inertia of the rotating assy. which in turn decreases torque output...
so do you want to spend the money trying to make a stroker survive in the 5k-7k range or where it really shines on the low end
Old Apr 16, 2008 | 11:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's an aftermarket 383 crank, it never had 400 journals to begin with.
For your application you don't need any magic parts, a typical stroker crank would be fine.
Old Apr 16, 2008 | 11:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Dragonslayer??? You see the price tag on those? Crap man, I bought my entire car for less then that.
What's your HP output desired here? I think with a mini-ram and a mild hydraulic cam (.509" hydraulic is fairly mild to me, since I know no other specs on that cam), i'm guessing you're not shooting for over 450HP, so a cast steel stroker crank should be fine.
I'm talking about an Ohio crankshaft $300 crank type of thing.
Old Apr 17, 2008 | 09:39 AM
82 Indy Z's Avatar
Thanks Sonic,
As for my HP desire I plan on making at least 400hp N/A and possibly a 150 shot or small turbo in the future. I would like to overbuild it a little to allow for more power in the future. I was thinking a 4340 steel crank from Eagle or Scat, but I did not want it to need to much balancing out of the box, since I plan on having the engine internally balanced. I have heard that cast steel cranks sometimes need lots of heavy metal to balance them.
my cam is a SLP 51010 with the following specs 220/230 dur lift is 502/510 on a 112 split. I plan on a upgrading the cam when I freshen up the motor.
What cam do you think would help reach my goal with my combo and still keep it streetable? I have a FAST engine management system, so tuning will be easier.
Thanks again,
OSC
Old Apr 17, 2008 | 09:59 AM
Sonix's Avatar
Car: 1982 Trans-Am
no no, you can't add a turbo to an NA motor, and you don't add a small one. Build it NA or build it turbo, but don't half a** it for either. Sounds like a good NA motor, so lets stick with that.
You don't need a 4340 crank, not until you're looking 800HP of block splitting HP in the face. RPM is what requires more strength in the bottom end, and it doesn't look like you'll be needing that.
A crank that's internally balanced is designed for such, it's not like you'll be slugging up an external balanced crank until it will become internally balanced. I doubt you'll need to buy a whole pile of mallory to balance any crank you buy.
That cam should work well for now, will give you a lot of grunt. Down the line you can upgrade it, but I think it's a pretty good setup for now. Any recommendations would only take away from the street-ability.
Old Apr 17, 2008 | 11:19 AM
82 Indy Z's Avatar
Cool,
So I can get by with a stroker crank designed to be internally balanced and I should be good then. If I want to get a bigger cam, what lift and duration do you think will be some what streetable? The car is a weekend driver only, so i can live with a less streetability. Plus with the FAST I should be able to tune it relatively easy.
Old Apr 17, 2008 | 11:52 AM
Sonix's Avatar
Car: 1982 Trans-Am
The XR276 or XR288 are both quite popular. Look up specs on those. I wouldn't go much bigger than an XR288 or else it will be sketchy. It's not that it's driveable or not (you got a stickshift, so no biggie), i'm just not sure how tolerant FAST is. I'm not wise to any FI systems really.
Old Apr 17, 2008 | 01:33 PM
82 Indy Z's Avatar
Cool, thanks for the advice and info. Think I will go with a eagle or scat stroker crank and then have it balanced. Any preferences? Thank you Sonix.
Osc
Azrael91966669
25
Jun 20, 2017 04:04 AM
Caspar
Jun 19, 2016 11:19 PM
Reborn756
Sep 4, 2015 03:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
