bluish exhaust smole
Old Apr 25, 2008 | 12:20 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
when i first start my car theres a little bit of bluish grey smoke. and i parked it today letting it idle to take some pics, and lil bit coming out then too. it sat during the winter for a cam change and other minor tuneups. what causes that? can it be, bad gas, carb running to rich or lean? any help thanks guys
Old Apr 25, 2008 | 01:10 AM
pyrofire127's Avatar
Re: bluish exhaust smole
Blue smoke is caused by engine oil entering the cylinder area and being burned along with the fuel air mixture. Just a small drop of oil leaking into the cylinder can produce blue smoke out the tailpipe.
Old Apr 26, 2008 | 12:16 AM
Engine: 355
anything i can do to make it stop? an additive or sealer?
Old Apr 26, 2008 | 12:42 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
I would pop your valve covers and check your valve stem seals.
Old Apr 26, 2008 | 12:43 AM
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
actually when this happens at startup it is the valve seals. It is common for small block chevy's and normally starts in the first 30,000 miles. You can add something like lucas to slow it but to totally repair you will have to pull the heads and have the valve seals replaced. It will run you around 150 bux or so plus all the gaskets and the seals to have it done at a machine shop if you can pull the heads yourself. It really isn't something you need to worry about it is just something we small block chevy guys have to live with.
Old Apr 26, 2008 | 01:19 AM
84Z28406's Avatar
It is not something we have to live with, and you don't need to remove the heads. If it is the valve seals (which it usually is) pull your spark plugs out, then use a tool that hold the valves closed with compressed air or feed in a few feet of clean nylon rope through the spark plug hole to keep the valves from falling into the cylinder. It helps if the cylinder youre working has its piston near top dead center. Remove your springs, keepers, retainers and all that. Replace the valve seals, put your springs and such back on, pull out the air tool or the rope, whichever you used and reinstall your spark plugs and plug wires. Fire it up and your done. I did in my driveway in a few hours and all it cost me was a couple bucks for the seals, 15 or so for a valve spring compressor, about 15 for new valve cover seals and a couple bucks for the rope. Total cost, an afternoon and 35 bucks.
Old Apr 26, 2008 | 01:50 AM
Car: 85 IROC-Z
Engine: 355 TPI
I didn't know that. Thanks for the info I know he'll appreciate it and I know I do.
Old Apr 26, 2008 | 07:14 PM
Engine: 355
i start it up and lil comes out, i rev it up while just starting it and it smokes bad. and cant tell while im driving but the exhaust smells real rich and it burns my eyes lol can the carb be to rich causen that or am i stuck with the valve seAls?
Old Apr 26, 2008 | 07:25 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
What would be causing it for my engine since I have brand new valve seals in it and now it is smoking on start up?
Old Apr 26, 2008 | 08:03 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Old Apr 27, 2008 | 12:23 AM
84Z28406's Avatar
No problem. If I had to pull the heads like you thought we had to, my car would still be smoking and I'd agree that it's something to live with and get used to.
As for having a shop do it, I'm not sure what they'd charge. It's an easy job though, so if you've got the time, do it yourself.
Old Apr 27, 2008 | 12:30 AM
Car: 85 IROC-Z
Engine: 355 TPI
If you already have replaced the valve seals then it would most likely be the piston rings. You can check this by having the compression checked. If there is alot of varience inbetween the cylinders it would confirm this. I have heard if you take a cap full of trans fluid and poor it down the carb it will help reseal the rings though. I would definately try running some lucas in it at your next oil change. when your are burning oil you are definately gonna produce higher emmisions. But it would normally only be higher at start up after sitting for more than a 1/2 hour or more.
Old Apr 27, 2008 | 12:32 AM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
well, most all chevys do that after some miles on them, as stated before, and its a fairly easy fix, as stated before.......
mine does it after it sits overnight, but yet the oil is still within the full marks after 3k on an oil change, i got 140k on the clock
look at it this way, its pre start up lubrication, chevy designed it that way, maybe, or maybe not
as for the tranny fluid trick, you can also hook a vac line up and the put in into the trans fluid, it will smoke like crazy for a few, but i know of a few guys who swear by it
Big Matt
Mar 23, 2012 09:32 PM
kendl77
Mar 21, 2011 09:40 PM
mgray1982
Oct 2, 2008 11:05 AM
89Iroc-ZL98
Jun 3, 2002 02:40 PM
Dana92RS
Nov 6, 2000 09:11 PM
