alternator wiring
Old May 3, 2008 | 01:37 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
alternator wiring
I just switched from efi to carb. Now my question is what do I do with the three wires that come from the alternator? I know one was for the fuel pump..???
Anyways what should I do with that?
Old May 3, 2008 | 08:24 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: alternator wiring
Nothing should need to be changed having to do with the alternator and its wiring.
Same wires plugged into the same alternator.
Old May 4, 2008 | 08:22 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I mean that little clip. The one that is connected to the fuel pump and all
Old May 5, 2008 | 11:33 PM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
pics? I'm totally clueless here. There should be no wires connected directly from the alternator to the fuel pump, unless your fuel pump has been replaced and upgraded with a hotwire kit to hook up the 12v power wire of the fuel pump to the alternator. Since you went carb, you'll need either that stock-style fuel pump and a regulator to feed the carb, a mechanical fuel pump, or an electric fuel pump designed to work at PSI's that carbs operate. Good luck
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
