Very simple question
Old May 9, 2008 | 02:33 AM
IroczCamar0's Avatar
Car: 1989 Pontiac Trans AM GTA
I tried searching but didnt find much but im doing my timing and i thought i knew where the #1 wire was but when i adjusted the timing the car ran like garbage i thnk i may have had it on the wrong wire, if someone can show me where the #1 wire is that would be great. Thanks
Old May 9, 2008 | 02:49 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Very simple question
number 1 is the front cylinder on the drivers' side
Old May 9, 2008 | 02:54 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Did you disconnect the computer ignition advance wire before setting the timing? If not, you will be fighting with the computer for timing control while trying to adjust it. It's a tan, one-wire plug, located just above the blower motor housing.
Old May 9, 2008 | 11:21 AM
well i did have it on the correct wire, as for disconnecting that wire i did not do that, i really hope timing it with that wire off fixes the problem. thanks again
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
