ignition module burnt..
Old May 9, 2008 | 06:22 PM
dethklok81's Avatar
Car: '88 Trans Am
Engine: 5.0 LB9 305 TPI
i had my ignition module replaced in oct 2007 because he burnt out on my way home to store it.. so i had no choice to replace it instead of towing it 6hrs home...
well i pulled it out of storage may 2nd and it burnt out may 6th... the part had under 1500km on it...
i just had the new ignition module replaced yesterday....
it was noted that the part that was replaced was not screwed in tight.. one of the screws was lose..
would this screw being lose cause it to burn out the part or is there anything i should be concerned about that might be shorting out my ignition module?
Old May 9, 2008 | 08:59 PM
RicksIroc86's Avatar
Car: 84 camaro z28
Re: ignition module burnt..
did you remember to smear the grease on the bottom before you put it on. ive seen that that will kill it fast.
Old May 9, 2008 | 09:06 PM
dethklok81's Avatar
Car: '88 Trans Am
sure did... the grease was on last time too...
just one screw was loose... so it wasn't flush..
Old May 9, 2008 | 09:17 PM
Car: 84 camaro z28
oh ok that may be it i would just put another one on there since they arent to expensive and make sure its screwed down good and see if it works. if that one burns out then you know you have a preoblem
Old May 9, 2008 | 09:23 PM
dethklok81's Avatar
Car: '88 Trans Am
i did replace it... it was the problem...
checked the coils and stuff.. everything was good..
put in a new ignition module and it fired right up...
just wondering if there might be anything else burning it out..
my other one failed under 1500km of use... but prob cuz it wasnt tight...
AGAIN
cruising at 120-130 and the car just shut itself of..
that sucks ALOT!!.. lol
but all is good now..
they're pretty pricey out here.. :S
cheapest i could find was $75...
im in canaduh...
i couldnt wait to order a part on the net...
need the car for work.. already missed 2 days.. lol
also... after shipping.. i would save $5 on the part.. lol
Old May 9, 2008 | 09:27 PM
Car: 84 camaro z28
lol well damn i got mine for 20$$ at the autozone here
Old May 9, 2008 | 09:30 PM
dethklok81's Avatar
Car: '88 Trans Am
i hate you
im gonna buy a spare just in case..
i tried a few places online...
shipping for that part to canaduh is like $25-30
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
