tuning rebuilt carb... before or after new ignition???
Old May 15, 2008 | 01:51 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i am finally finishing rebuilding my carbuoretor, and am wondering, how much tuning i should do with my old ignition setup before putting my new ignition setup on?
[new ignition setup: digital mallory VI-AL cd ignition, matching billet distributer, and 51,000 V coil, w/ msd 8.5mm superconductor plug wires]
Old May 19, 2008 | 12:09 PM
impaled's Avatar
Re: tuning rebuilt carb... before or after new ignition???
anybody?
Old May 19, 2008 | 12:43 PM
kerplunk318's Avatar
I would get all that new ignition in there and then tune the carb. Barry Grant says you should even have your timing set just right before you even start messing with the carb. So just get those ign parts installed, set your timing, and go from there.
good luck
Old May 19, 2008 | 12:56 PM
impaled's Avatar
you dont think that swapping all of the ignition over first would make it harder to tune/get it to run correctly?
Old May 19, 2008 | 03:15 PM
it should actually be easier to tune the carb after the ignition upgrades
Old May 19, 2008 | 04:28 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Assuming your ignition works now its not going to matter.
Old May 19, 2008 | 04:42 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Is the old ignition the computer controlled dist? Replace the ccc-qjet with a holley? If so, you can tune to the old setup but the stock dist won't get the commands it needs to properly advance the timing.
Either way, always set timing and tune up your ignition before touching the carb.
Old May 19, 2008 | 07:44 PM
impaled's Avatar
no, it was non cc long before the rebuild, and i didnt know if it would be harder to set up after everything was changed over.
Old May 20, 2008 | 06:38 AM
naf's Avatar
naf
If it's working fine now go ahead and adjust the carb. Just make sure the timing's set properly, advance is good and it's all in working order. It's hell trying to tune out a mis-fire with an idle mixture screw.
9192camaro
16
Feb 3, 2019 12:21 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
Thornburg
Aug 30, 2015 08:05 AM
