NO OFFLINE AND NO TOPEND POWER
Old May 18, 2008 | 01:00 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
I am having a little difficulty trying to determine what the problem is. On the first 500 miles of break-in, I had power that would spin the hell out of my tires and that would only be at 3/4 throttle. I understand that fact that I changed to MT ET Street tires, but I should be able to spin those up atleast around full throttle. The engine over heated once and I did test my compression 180-190 psi on all cylinders, Changed the hydraulic flat tappet cam springs and lifters, verified valve lash is at 0, timing set at 38 btdc. changed to an aluminum water pump,installed new intake and exhaust gasket, changed plugs, changed to an Pertronix HEI race dizzy, new plug wires, new stall converter and thermostat. It also has no more power after 6200 rpm, just stays flat and will not pull anymore, but the engine doesn't break-up or no type of engine miss.
You guys have any clue that could help me out? I am thinking maybe something wrong with the carb or heads. Checked cam lift and springs again and no problems there.
Thanks for any help.
Old May 18, 2008 | 01:36 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: NO OFFLINE AND NO TOPEND POWER
Originally Posted by mcbchild
... It also has no more power after 6200 rpm, just stays flat and will not pull anymore, but the engine doesn't break-up or no type of engine miss...
This sounds exactly like the engine is leaning out due to lack of fuel.
Check the fuel pressure during an acceleration run. It may have picked up some trash in the fuel system.
Old May 18, 2008 | 07:47 PM
mcbchild's Avatar
I will try that after I have the carb rebuilt and put back on the engine, I was also thinking of changing from a hi volume mechanical carter fump pump to a holley blue electric fuel pump.
Old May 29, 2008 | 10:49 PM
mcbchild's Avatar
I just got my carb back from the shop and was told that it had a blown power valve and and the air/fuel mixture settings were not set correctly, but nothing else was found bad or wrong with the carb. I also replaced the carter mechanical fuel pump for an Holley black electric fuel pump w/regulator. SO now I will see what it does at the track this weekend.
Old May 31, 2008 | 03:57 PM
mcbchild's Avatar
ttt
Old May 31, 2008 | 10:29 PM
mcbchild's Avatar
Nope, didn't make much difference. Could it be something wrong with the heads? I did overheat the engine a couple of times when the water pump belt fell off a couple of times. but i did a compression test and was 180psi in one cylinder a close to 190 psi in the other cylinders. no white smoke or anti-freeze in the oil and vice versa.
Old Jun 2, 2008 | 09:48 AM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Maybe you can try checking the timing mark. Make sure the piston is at TDC and see where the timing mark is actually pointing. Seen it a couple times.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
