Car is slow/has no power
Old May 19, 2008 | 03:15 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I cant figure out what is wrong with my car. It is extremely slow when driving it. It is a 305 TPI that just had a cam put into it (260/260 duration .444 .444 lift 112 LSA), and its an automatic. The car doesnt really shift right either but I dont know if that is the whole cause of my problem. What should I look into to fix this problem.
Old May 19, 2008 | 03:53 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: Car is slow/has no power
First you need to make sure your TV cable is adjusted properly. If its off, 10 miles can wreck the trans.
Old May 19, 2008 | 04:08 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I know that the cable is misadjusted. I already tried adjusting it but it wont work (I dont know if the cable or something is bad on it or not). I know the cable adjusts shift points, firmness etc, but can it cause my car to be very slow?
Old May 19, 2008 | 04:36 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Slower, but probably not the problem. Misadjusted, it can destroy the trans quick.
After the cam install, the car is slower? Was it installed correctly? New intake gaskets? Timing reset correctly?
Old May 19, 2008 | 07:44 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I never drove the car before I put the cam in and it was installed correctly as fas as I remember. It has new intake gaskets, and the timing was reset to 6 degrees advanced.
Old May 19, 2008 | 10:34 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Ah, ok. So your saying your car is just slow. Kinda hard to imagine the slow your talking about.
What about the regular maintenance stuff? Distributor cap, plugs, wires, fuel filter, dirty throttle body? Compression?
How does the car sound when you get on it?
Old May 19, 2008 | 10:37 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Cap, plugs, wires, and rotor are all brand new. The fuel filter was replaced about 2 years ago. Throttle body was cleaned as well. When I get on it, it seems to have a little stumble but not bad.
Old May 19, 2008 | 11:00 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Well, the only thing I can think of, is you might need to advance your timing. That cam has a good bit more duration than the stocker, and larger cams need more timing.
I would send it up to around 12* and see how it feels. Most guys with a stock car run 10 for performance. With my Lt1 cam and 1.6 rockers in my old 305, the motor liked the timing at 18*. It made a big difference.
Old May 20, 2008 | 08:18 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I guess ill try that next. Does anybody else have any other suggestions.
Old May 20, 2008 | 08:22 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Get a different car.
T.P.I = SLOW.
Old May 20, 2008 | 08:24 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
When i put a larger cam in my camaro (1991 tpi), with a bunch of other stuff (heads, headers, ec. etc.) the car actually went slower.....problem...knock sensor was pickup up phantom signals from cam lope....put lt4 knock sensor in...helped a ton......computer reprogrammed helped even more...runs like a raped ape!!!
Old May 20, 2008 | 10:47 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
TPI=slow lol, not helping the guy
Knock sensor makes sense. Computer reprogramming helped for you probably because you are speed density, where as this 85 is MAF. Probably wont help in his case.
You WILL feel the increased timing, whether its the slow problem or not....idk.
BRoss99
Aug 10, 2025 05:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Brcharrelson
Aug 26, 2015 07:47 PM
novaderrik
Aug 10, 2015 12:44 PM
