Will this pulley fit my alternator?
Old May 21, 2008 | 05:12 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Im looking at getting a smaller pulley for my alternator to get better charging a idle, the problem is its harder to find 5 groove overdrive pulleys. It is a V-belt setup, but it has the 5 groove pulley. This pulley was stock for some ford car, but will it fit on my alternator without any problems, it looks like nearly everything matches up but I wanted to make sure?
http://store.alternatorparts.com/ind...OD&ProdID=1274
Old May 22, 2008 | 10:44 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Re: Will this pulley fit my alternator?
Anyone have a clue?
Old May 23, 2008 | 01:20 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yes, i'm pretty sure it will work. 17mm hole is the same, so you should be fine.
I can tell you i've taken Ford serpentine alternators (1993 taurus) and put on 1984 GM V-belt pulleys on the shaft with no problems, so what you're doing is similar enough.
Old May 23, 2008 | 01:23 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
I was thinkin so as well just wanted to see what everyone else said. thanks for the reply
evilstuie
Apr 14, 2016 08:52 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Cleotiz
Aug 23, 2015 12:07 PM
Navy8125
Aug 22, 2015 07:13 PM
