oil shooting from dipstick
Old May 25, 2008 | 02:27 PM
xpbxwrecked1's Avatar
Car: 87 mustang gt 89 camaro
Engine: 302 355 tpi
Transmission: manual
Axle/Gears: 3.55 and 3.42 posi
i put in another 305 tpi and the oil is shooting out of the dipstick..what could be the problem...it did it on the other motor too
Old May 25, 2008 | 03:25 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Re: oil shooting from dipstick
I have no idea why but it sounds like you have alot of crankcase pressure built up.
Old May 25, 2008 | 03:33 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
check your valve seals also could be rings. check spark plugs for oil deposits make sure pcv is not cloged although it doesnt usually make much of a diff if theres enough pressure to blow the dipstick out.
Old May 25, 2008 | 04:27 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Do you have a functioning PCV valve (if you shake it, it should rattle)? Is the opposite side valve cover vented? Does the engine seem to burn oil?
Old May 25, 2008 | 04:49 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
i had a 78 monte carlo with lg3 305(even weaker than lg4) that did the same thing, my auto instructor told me he seen it before and what was from excessive crankcase pressure due to extreme blow-by of the rings, and that he has never seen any engine with that much blow-by last more than a month. 2-days after diagnosing my 78 the engine threw a rod out the side of the block.
Old May 25, 2008 | 09:41 PM
Engine: 302 355 tpi
the pcv valve is new, and the motor doesnt burn oil, the opposite side is hooked up to the throttle body
Old May 25, 2008 | 09:46 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
After my first re-build, I had the same problem when I got on it. It really sucked cause the oil would spill onto my exhaust and smoke like crazy! Turned out the land area of the #4 piston was cracked which caused blowby and excessive crankcase press.
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
BDR
Nov 7, 2015 03:05 PM
KCG
Sep 23, 2015 09:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
