gas mixing in my oil whats going on?
Old May 26, 2008 | 07:57 PM
jlc84cam350's Avatar
Car: 84 camaro, 92 yota 4runner
Engine: 305 lg4 out of 81 z28
Transmission: th350
Axle/Gears: Not sure believe its 3.23
my oil smells like gas, and i am pretty sure that it is getting gas from somewheres. I don't know whats going on could it be possible that i'm set up way to rich? my timing is definetly off, i changed to an edelbrock intake and just cant get it set up right. Check ---> http://www.youtube.com/watch?v=2IarHyzXQgU
Old May 26, 2008 | 08:02 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: gas mixing in my oil whats going on?
its running to rich, your washing out the rings.
Old May 26, 2008 | 08:03 PM
Transmission: th350
how do i lean t out? is their a needle or something i have to twist?
Old May 26, 2008 | 08:07 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
If you have a mechanical fuel pump check the diaphram.
Old May 26, 2008 | 08:09 PM
Transmission: th350
sorry, i'm not 100% english, what's you mean by diaphram?
Old May 26, 2008 | 08:14 PM
Transmission: th350
i might have an idea why its running rich, i did this cause she was leaking and was told i could just cut it, i blocked off the return line with a bolt that goes to the tank from the pump, could this be a problem?
Old May 26, 2008 | 09:06 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
that return line would be good to have... get that hooked back up properly
Old May 27, 2008 | 04:50 PM
dayton's Avatar
Car: 1987 firebird custom
Engine: 350 crate
Transmission: 700r
Axle/Gears: 81 z28 rear
if your running a rochester then thats probably your problem, its killing me at a fast pace and is always a scene to adjust.drop it if so and go DEMON
Old May 27, 2008 | 06:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
95% of the problems with Rochester carbs is what is done to them, not what they do.
You said the return line was leaking and you cut it and blocked it off. If you did that as you described, you should have fuel pouring out of the return line of the pump.
If you blocked off the return line from the pump with a bolt, the pump will put out too much pressure to the carb, causing it to flood.
The diaphragm is part of the mechanical pump. If it leaks, it will put gasoline into the engine oil.
It sounds like you need to rehook up the return line to the pump, though.
Old May 27, 2008 | 09:15 PM
Transmission: th350
i didn't have a chance to try it out today, but ill do my best this weekend, i sure hope thats the problem,
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
92camaroJoe
Aug 13, 2015 06:07 AM
