what do you think of my combo?
Old May 27, 2008 | 06:39 PM
irocbrninrubber's Avatar
I was wondering what you guys think of my combo and how it might do. I have a 355 freshened bottom end with speedpro flat top pistons for a 9:5:1, holley systemax II heads 185cc 2.02/1.6, rpm air gap, 276hr 224/230@.050 lsa110, 1.6 rr backed by a t56. I choose that cam thanks to the help of people here, because i wanted to go with a bigger cam that wasnt going to be very street friendly and as far as the heads i got them for a real good price. The rotating assembly is getting balanced and after i get that back i should start putting it back together. for your opinions and help.
Old May 27, 2008 | 06:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like it's going to be a runner.
Back it up with proper transmission/stall/gears, it'll be a terror.
Old May 27, 2008 | 07:08 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Re: what do you think of my combo?
Sounds bad once you get it goin in a car post a video!
kevin
Old May 27, 2008 | 07:21 PM
Thanks for the input. As soon as i can i will post pics and videos. I might take leave just to finish it. What kind of numbers do you think i will put down? I ask this because i saw a article on superchevy where they had pretty much the exact same set up for the exception that they used a flat tappet cam and i am using a hr but the duration is the same and i am using a 110 lsa and they had i think it was a 112. They made 429 at the crank, but the machinist taht is balancing my assy said that i would be lucky to get 330 to the crank. Do you agree with what he said or is superchevy pretty close to what i will be running? thanks again.
Old May 27, 2008 | 07:30 PM
I would go with the superchevy. With your set up ya well over 330.
kevin
Old May 27, 2008 | 09:03 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Very similar to my 357, just a hair less compression and cam... its very driveable, but oh-so-satisfying to hear the bbBBPPPPRRRRAAAAPPPPPPPPPP!!! when you put your foot down, and 'potato potato potato...' when its idling (say that to yourself out loud and you'll understand lol) Its a pretty nasty little mill, and sounds every bit of it, but was still tame enough to be a daily driver for a year - yours should be more or less the same
I'd guess 370 crank hp through mufflers.
Good luck!
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
