Clunking after turn off
Old Jun 1, 2008 | 12:57 AM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Car: '86 Tran Am 305 tpi
Ok everyone I worried about my engine. After my engines all warmed up and drive for a while then get home after and turn it off. I hear *Clunk* pause *Clunk*. I dont get it Is it cause I have a bit of a lead foot...
Also what is aknock sensor and what do I have to do to put 1 in?
Old Jun 1, 2008 | 07:48 AM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
Re: Clunking after turn off
sounds like its "dieseling", carbon buildup getting hot and causing detonation and keeping it running.
though, i didn't think F/inj could do that, because the injectors shut off?
Old Jun 1, 2008 | 01:13 PM
Engine: 350/350/LS1
Could you please describe detonation to me. Im alittle new to all the technical terms...sorry
Old Jun 1, 2008 | 11:43 PM
Engine: 350/350/LS1
bump
Old Jun 2, 2008 | 12:39 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Detonation (also called "spark knock") is an erratic form of combustion that can cause head gasket failure as well as other engine damage. Detonation occurs when excessive heat and pressure in the combustion chamber cause the air/fuel mixture to autoignite. This produces multiple flame fronts within the combustion chamber instead of a single flame kernel. When these multiple flames collide, they do so with explosive force that produces a sudden rise in cylinder pressure accompanied by a sharp metallic pinging or knocking noise. The hammer-like shock waves created by detonation subject the head gasket, piston, rings, spark plug and rod bearings to severe overloading.
Mild or occasional detonation can occur in almost any engine and usually causes no harm. But prolonged or heavy detonation can be very damaging. So if you hear knocking or pinging when accelerating or lugging your engine, you probably have a detonation problem.
F-body driver
Mar 6, 2023 11:44 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
