Very simple fluids question?
Old Jun 2, 2008 | 08:57 AM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
Looking to check my trans fluid, is that the cap behind the lower driverside pulley? If not where is it?
Or is that for the power steering pump?
Which leads me to my next question, does my Camaro take trans fluid in the power steering system anyway? (my BMW did)
Old Jun 2, 2008 | 09:36 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Very simple fluids question?
Yea, ATF and power steering fluid are virtually identical, you can interchange them.
No, the power steering system is up at the engine front. You check your tranny fluid via your tranny dipstick, back of the engine bay. I think it has a yellow handle and should say trans on it
Old Jun 2, 2008 | 11:35 AM
Car: 92 Camaro RS
Axle/Gears: Stock
Cool that is what I figured.
Thanks.
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
