Anyway to fix Blue Smoke?
Old Jun 3, 2008 | 11:51 PM
Jix01's Avatar
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
So my car puffs out quite a bit of blue smoke in the morning and if it sits for 30 minutes at the least.Anyway to fix this? i have 182,000 miles just didn't know what i could replace to stop the blue smoke cause its really annoying especially if im in a parking lot full of people and i go to start my car and it smokes everyone out.i believe it burns about a half a quart a month. any ideas would help..Thanks!
Old Jun 3, 2008 | 11:59 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: Anyway to fix Blue Smoke?
Typical chevy problem. Valve seals are toast. When the engine sits oil leaks down through the valve guides and when you start it up it gets burned hence the smoke.
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
pull heads, have them rebuilt easy and not too hard on the wallet....
Old Jun 4, 2008 | 01:07 AM
Jix01's Avatar
Engine: 305 5.0 TBI
how much should i be looking to spend on having the heads rebuilt?
Old Jun 4, 2008 | 01:17 AM
Car: 1991 Z28 1LE
Transmission: 4l60e
umm depends on what all u have done...just give ure machine shop a call and ask....bout 200 bucks or so....rough guess...
Old Jun 4, 2008 | 06:34 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
how many miles is on the motor?
if its as high as Im guessing, I would rebuild the entire motor.
Old Jun 4, 2008 | 11:44 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Valve seals costs $40 and you don't have to pull the engine or the heads.
Common problem. Start there, if that doesn't fix it, then go on.
Ask for the Fel-pro viton positive seals for your intake side. Buy two sets (an extra set of INTAKES, for the exhaust side as well) and put them on using a spring compressor.
Old Jun 4, 2008 | 07:47 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
hey sonix i remember reading something about using intake seals on the exhaust side but i dont remember y
Old Jun 4, 2008 | 08:03 PM
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
Axle/Gears: 9 bolt 3.27
Mine does this too, I suspected valve seals
Old Jun 4, 2008 | 11:25 PM
Sonix's Avatar
Car: 1982 Trans-Am
"exhaust seals" as the parts stores call them, are typically the umbrella seals. They don't really seal very well. They let oil seep through, in order to lube/cool the exhaust valves.
Intake seals are meant to completely seal, so they are the positive style seals.
You can buy intakes and put them on both sides though. Many people do this with no ill effects.
Old Jun 5, 2008 | 08:31 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
first check the easy stuff . likely that you do need new valve seals , can be done in car . most likely the drain holes on the lower front & rear of the cylinder heads have become sludged up and oil is not draining back to crankcase as it should . easy fix , disconnect battery , remove valve covers , rod out drain passages . worked for me . good luck .
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
Linson
Sep 21, 2015 01:08 PM
Accerrito22
Sep 5, 2015 09:34 PM
