New Brodix 400 replacement block
Old Jun 8, 2008 | 09:41 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
I saw something the other day at a buddy's shop that was cool. A new 400 block from Brodix. 75lbs lighter than a little M and cost about $1400.00. It had three freeze plug holes and has 350 size mains. They came from PBM Performance.The shop I hang out at just about refuses to build a stock 400 block because the castings are so poor.
Old Jun 11, 2008 | 08:13 PM
RebornFromAshes's Avatar
Re: New Brodix 400 replacement block
You mean $4,100, not $1,400. If the block was $1,400 it is used, and probably been repaired once or twice. If they were $1,400 you would see a large number of these flying around.
The Brodix blocks are nice. I am not sure about any shop that refuses to build 400's because the blocks are so poor. People have built 4.25" bore engines off of the stock 400 blocks. These blocks have also been pushed to over 600 HP. Grumpy Bill Jenkins ran these closer to 700 HP at high RPM with some cap work to support and align the 2 BOLT CAPS he ran on these engines.
Granted, a random number of blocks were poorly casted and would not be good for high power or big overbores. Anyone deciding to really push the limits of a factory block should also be making an effort to find a solid core. It sounds like your shop wasn't doing this and broke a few bad castings and decided the casting errors were common to all 400 blocks.
Old Jun 11, 2008 | 08:23 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Correct.
The Brodix blocks are around $4,100 and the Dart little Ms are around $2,500.
And if it is used, 1,400 is a screaming deal. I would have the block meticulously checked over.
Old Jun 11, 2008 | 08:26 PM
Engine: 355
NO $1400.00 and yes its new out of the box. A Little "m" is only $2500.00. Bill Jenkins ran the blocks new not 35 years old. .PSI has a great reputaion and does not want to tarnish it by sending out junk. When you use a old block you are taking a chance. It's your car and your cash. They will build you a engine with a old 400 block if thats what you want. I was wrong it is a DART not Brodix.
Old Jun 11, 2008 | 08:55 PM
Engine: 355
This is a Dart block not a Brodix. My bad!!!!!!!!!!!!
Old Jun 11, 2008 | 09:00 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
okay it is still a $4,000 block...
Old Jun 12, 2008 | 06:12 AM
Engine: 400
No it's not. A little m is 2,500 new. This is a good deal assuming someone doesn't get ripped off or screwed over.
Old Jun 12, 2008 | 09:42 PM
Car: 91 RS
Engine: 350 vortec
think your confused the little M is 2500 new how ever that isnt the engine he is talking about as it certainly isnt new... they have a new billet block...but if you need to know the price... you cant afford it
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
BBSDesigns
Aug 11, 2015 07:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
