Engine Loses RPM then Won't Start
I've got an 86 t/a with an LG4 engine. I've put in a comp cams xe262 cam, a set of hedman headers, a edelbrock performer rpm q-jet manifold and got my carburetor rebuilt last year. Now I'm having a problem where after driving around and heating up the engine, when i stop at the lights, i start to lose rpm, stall, and then can't start again. What could this be? Is my mechanical fuel pump not living up to my mods? Am I losing pressure in my fuel lines? Is there something wonky with my carburetor? Am i experiencing heatbog?
Transmission: 4L80E/4L80E
Probably your ignition getting hot. May be vapor lock, though.
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Engine Loses RPM then Won't Start
I hate when my motor is acting wonky
how is your fuel line ran from the pump to the carb. keep it away from the engine
get a spark tester and check to see if you are getting spark in these conditions
take off you air cleaner and see if the accelerator pump charge is getting to the nozzles
sometimes you need to tune the idle air jets when the car is hot. espesially during the summer months
Sounds like an ignition component getting hot. May be vapor lock, though.
