TIMING ISSUES PLEASE HELP!
Old Jun 15, 2008 | 02:26 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
I installed a Compcams XR282HR-10 into a 383 TPI motor and I'm having an idle issue with it. When I set base timing to 10 degrees the engine is surging/hunting for an idle constantly. I've had to retard the timing to less than zero in order for the idle to even out not to mention that the headers started glowing. The cam is installed straight up on a gear drive. My scanner is showing between 25 and 28 deg at idle. What's happening here? Did I get a screwed up cam or did I screw up? Thanks in advance(no pun intended). If you need more information please let me know.
Old Jun 15, 2008 | 04:05 PM
pwdbychevy's Avatar
Re: TIMING ISSUES PLEASE HELP!
ttt
Old Jun 15, 2008 | 04:20 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
hei? my old hei had to run at 34deg and like 50 all in to run best. at 10deg would pop and go crazy. my new msd system runs at 24 and 36 all in.
Old Jun 15, 2008 | 07:40 PM
pwdbychevy's Avatar
I'm running a External coil HEI distributor but the actual ignition is a Jacobs Ultra Team. How would retarding the timing cause the headers to glow? It melted my JET fan switch connector.
Old Jun 15, 2008 | 07:47 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
by retarding the timing you have moved the point of combustions further into the exhaust stroke ie the charge is still burning strong as it enters the headers
Old Jun 15, 2008 | 08:37 PM
pwdbychevy's Avatar
But why is it that when I advance the timing the engine starts to hunt for an idle? The idle evens out only when the timing is retarded. Could this be a symptom of the camshaft and crank marks not being lined up correctly?
Old Jun 16, 2008 | 08:29 AM
pwdbychevy's Avatar
ttt
Old Jun 16, 2008 | 05:40 PM
pwdbychevy's Avatar
anybody?
Old Jun 17, 2008 | 09:02 PM
Car: 91 RS
Engine: 350 vortec
you are still running TPI? most likely your tune
Old Jun 18, 2008 | 07:55 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
ok that cam will never run smooth no matter what you do
who programmed the prom because it will take a bad mamba jamba to get that right
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
djmarch
Aug 9, 2015 05:27 PM
86Base
Aug 8, 2015 01:34 PM
