Oil Leak
Old Jun 16, 2008 | 05:26 PM
69-Camaro's Avatar
Oil Leak
I have a 1990 with a 305. It is dripping oil from the dust cover on the trans. What should I look for? I have heard that the intakes leak, valve covers leak, oil sending units leak? It is leaving a good size puddle under the car and is quiet annoying. How hard is it to fix these leaks? Is it a garage job or 2 buddies and a case? I also noticed the block is wet above the oil filter? That would be a valve cover?
Old Jun 16, 2008 | 05:41 PM
Pop45398's Avatar
Car: '91 RS
Engine: 355 on a stand
Axle/Gears: 3:42
Re: Oil Leak
Check the oil sending unit behind the driver's side head. I've seen several of these leak.
Old Jun 17, 2008 | 06:34 PM
Trick414's Avatar
Car: 1991 RS Vert
Engine: LO3, 305, TBI
Re: Oil Leak
The intake and valve cover job is literally a 2 buddies and a case. My buddy and I did it in a couple of hours taking it easy and taking pictures along the way. There are a lot of hoses and other items in the way, but once you get familiar with them, they become much less intimidating.
I had a lot of oil on the back passenger side of the intake/valve cover area. I pulled the valve covers off and pulled the intake.
Mostly, the job is simple cleaning and new gaskets. It's a fun weekend buddy job that will make you much more familiar with your top end.
Old Jun 18, 2008 | 08:34 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Oil Leak
take off the dust shield
go to the car wash
leave the car running
spray the back of the pan and the area that is under the valve cover- just spray it all down with degreaser
hose her down
drive about 20 miles and have a look
I think it might be the rear main seal and the valve cover gasket
Old Jul 7, 2008 | 06:49 PM
69-Camaro's Avatar
Re: Oil Leak
Ok, have an update here. I switched to synthetic oil (10/40) Mobile 1 and wow! Now the car drips oil as I move it. It is leaking much worse! Is this the synthetic oil or have I blown a seal? I cannot find where it is coming from? The valve covers are dry and the heads around them, the intake is wet back by the distributor but not enough to warrent this kind of oil on the ground?? The only thing I can think of is rear main? I hope not? Anybody have a trick to find an oil leak without standing on your head or ripping the engine apart to find that you just created another leak?
Old Jul 8, 2008 | 01:41 PM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Re: Oil Leak
Well, synthetic oil is much thinner than regular oil so it's just making it easier to leak out of wherever the leak is. I'm thinking rear main as well.
Old Jul 8, 2008 | 01:57 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Oil Leak
Pull the dust cover off and check the backside of the flywheel. If it is rear main you will see oil that has slung off the flywheel. Also if it is a bad leak you might see it driping.
Old Jul 8, 2008 | 09:52 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
Re: Oil Leak
i have had the same prob. even though the back of the block by oil sending unit isnt that bad or "wet" that was my whole problem and that leak is gone. pretty easy to change too
Old Jul 8, 2008 | 11:43 PM
69-Camaro's Avatar
Re: Oil Leak
Ok, another update. The bell housing is wet and around the oil filter is wet? The oil sending unit seems not to be leaking, but that would not throw oil up to the top of the engine? Pulled the dust cover and it is dry as a bone in there! No rear main leak!! Seams like an intake leak, just no pooling oil on the rear of the block? Is there another leak point between the intake and the bell housing? The distributor is not leaking. I just don't see what would cause pooling of oil on the ground?
Here is a stupid question: If the engine was overfilled with oil, where would it come out? Should I look there if there is a place? I just got the car and could have overfilled the engine. Because the leaking is slowing down and the dip stick (not myself) still reads full?? Maybe I am the cause.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
