First upgrade?...
Old Jun 17, 2008 | 08:19 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
First upgrade?...
Im in the process of purchasing a '83 Z28 auto and was wondering what all of you suggest as the 1st upgrade?...im putting a digital gauge cluster in b/c a couple gauges are broke(speedo)...im looking for ideas b/c i cant make up my mind...i was thinking rachet shifter and manual valve body...looking to spend under $400 if possible
Thanks Chas
Old Jun 17, 2008 | 08:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
What's first depends upon what you want out of it. Manual valve body doesn't make sense for anything but a full-up dedicated race car. Ratchet shifter only if you're racing it.
90% of other modifications require full exhaust upgrades. But, that's going to cost you more than $400. Next choice would be subframe connectors, which will cost you less than $400.
Old Jun 17, 2008 | 08:42 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Re: First upgrade?...
You could always put a performance shift kit in it. Or mabey an exsaust system.
kevin
subframe connectors wat do they do for you i really dont know if i should get them or not?
kevin
Last edited by GoodlookinRS; Jun 17, 2008 at 08:44 PM. Reason: Automerged Doublepost
Old Jun 17, 2008 | 09:04 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Thanks for the warm welcome...it will be used for 50% cruising(gf) and 50% racing(me)...i plan on building a 350 from the block up so i dont really want to do any major engine upgrades to the stock 305...i was looking at an exhaust system but wasnt sure of which route to go...i like the sound of the flowmasters...i plan on gutting the cats to get her a lil louder either way...
Thanks for the help, Chas
Old Jun 18, 2008 | 07:51 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I would listen to the kid
me personally it would be subframe connectors
Old Jun 18, 2008 | 11:19 AM
five7kid's Avatar
It could be argued that subframe connectors should be the first modification to any of our cars.
Old Jun 18, 2008 | 02:30 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i would stay away from tranny mods unless you plan on running a tranny cooler.
exhaust would be my #1... you could at least get a catback for that.
subframes would be good, but the stock 305 isnt exactly a powerhouse engine, but they are definitely a necessity down the road.
i would probably also consider shocks and struts, depending on the ride condition. they can make it alot more comfortable/fun. depends what your goals are.
Old Jun 18, 2008 | 02:50 PM
five7kid's Avatar
The door window corners were cracked when my car had the original V6. Power isn't the issue, although more power makes them more necessary.
Old Jun 18, 2008 | 03:03 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
thats exactly were mine cracked on my 82' although sub frame connectors weren't my first mod they were defiantly on the to do list, id do exhaust first even if you don't get a lot more out of it at least it'll sound good
Old Jun 18, 2008 | 04:34 PM
Tony_B972's Avatar
Car: 86 IROC
Engine: 383 (in progress)
Transmission: tko 600
I have to agree w/ the kid too, if u wanna do ANYTHING race w/ it sub. connectors are first and foremost, if not that get a cat-back or if ur into it a better deck/speakers
Old Jun 18, 2008 | 10:07 PM
vette gator's Avatar
Car: 85 Z28
All the above is good advice, but I have another idea. I'd hang onto the $400 until you see what needs to be replaced. Even though my car was generally in good shape when I bought it, I had to put in a new heater core, water pump, radiator, steering box, PS pump and coolant temp sensor and the tires had to be replaced not too long after. Everything is good now, and I'm having a ball driving the car, but it definitely consumed some cash in the beginning. Hopefully, your car won't need as much, but you might run it for a little while before making any upgrade decisions. I don't think I've seen anyone mention a wonderbar, but that's definitely an upgrade to consider (I added one of these to my 85 Z28).
Old Jun 19, 2008 | 08:18 AM
impaled's Avatar
Originally Posted by vette gator
All the above is good advice, but I have another idea. I'd hang onto the $400 until you see what needs to be replaced. Even though my car was generally in good shape when I bought it, I had to put in a new heater core, water pump, radiator, steering box, PS pump and coolant temp sensor and the tires had to be replaced not too long after. Everything is good now, and I'm having a ball driving the car, but it definitely consumed some cash in the beginning. Hopefully, your car won't need as much, but you might run it for a little while before making any upgrade decisions..
that is another good piece of advise, depending on how limited your budget is. i have yet to buy a third gen that didnt need somewhere between $200 and $400 in repairs just to get it to be a reliable DD.
but if you do choose to spend some money on mods, i think exhaust would make you the happiest. maybe a little power boost, PLUS a better sound that make driving it more fun.
Old Jun 19, 2008 | 04:50 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
For now i will hang on to the money i never dawned on me to look into wear and tear items b4 mods...ill wait and see how it drives for a while but ill def put in the subframe connectors...
Thanks a lot guys
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
383backinblack
Oct 14, 2015 08:50 PM
Zell1luk
Sep 29, 2015 10:36 AM
