Buyin a Cam Tomorrow!!! what am i forgetting???
Old Jun 19, 2008 | 11:06 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
The list so far:
-Cam: 08-466-8 268XFI HR13
-Springs: 26918-16 LS1 Beehive Springs
-Retainers: 787-16 Retainers
The items in question:
-What head gaskets would you guys recommend? should i just go with the felpro HS7733PT9 ???
-Rocker arm Studs: 7/16" or 3/8" ??? Labor required? Difference??
-What am i Forgetting?
Thanks for the help guys!
Wish me Luck! Ive never done this before!!!
-Boldguy
...Thats what she said
Old Jun 19, 2008 | 11:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Stock head? Are you pulling them to have the guides cut for the lift?
3/8" screw-in studs will be fine. Labor will be removing the press-in studs, machining the bosses for the stud shoulder, tapping the holes, and installing the studs. Probably $150-$200, depending upon your shop.
PROM burning is probably in your future.
Old Jun 20, 2008 | 12:08 AM
boldguy's Avatar
Car: 1992 Z28
Re: Buyin a Cam Tomorrow!!! what am i forgetting???
so the stock "113" aluminum L98 Heads have press in studs? And yes, these heads are stock, i thought they would support the lift of this cam...
Old Jun 20, 2008 | 10:07 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yes they do. Also, you gotta tell us if you're running 113 heads, I didn't read that in your original post eh?
That's a high lift cam, i'd make sure to measure and check it. It most likely needs machininig.
Your rockers and studs need to match. So if you're using 3/8" rockers, you need 3/8" studs. That size is fine for your application.
Does the retainers come with locks? You'll need those.
those gaskets will work fine.
Old Jun 20, 2008 | 03:04 PM
five7kid's Avatar
I missed the "Location: Cali" part. You'll need external exhaust plumbing for the EGR valve, a la Vette L98.
Old Jun 20, 2008 | 08:29 PM
boldguy's Avatar
Car: 1992 Z28
excellent information guys. Not what i wanted to hear, but thanks so much for these bits of info.
About the EGR plumbing: How is this done? any available Kits? Etc.
Just when i have decided on the cam i want, it turns out it wont work.
Good thing i find out now and not after i turn the key
Old Jun 21, 2008 | 12:10 AM
boldguy's Avatar
Car: 1992 Z28
Alright Kevin you have sold those springs and retainers. do you guys get comission? I'ma place the order on Summit. Dont know if that link will work for my shopping cart. So i have decided to get the LUNATI
Part Number: 54779LUN
Duration @ .050 In/Exh: 215* / 224*
Valve lift w/1.5:1 Ratio: .489 / .489 (W/1.5:1 Rocker arm Ratio. Im using 1.6's)
LSA: 112*
Springs: Manley 22410-16
Retainers: Manley 23652-16
Now THIS combo is definately going to work right?
PS for those just joining us the "combo" is Stock resurfaced valve jobbed "113" heads off of a 1991 vette.
Old Jun 21, 2008 | 12:35 AM
boldguy's Avatar
Car: 1992 Z28
The heads have locks already, is this still necessary?
Old Jun 22, 2008 | 12:46 AM
boldguy's Avatar
Car: 1992 Z28
SUNDAY=Purchasing the goods
The Goods:
-Lunati Cam
-Lunati Springs
-Gasket set
Questions:
1. Will the headers on my Car(edelbrock) work with these heads(d-port)?
2. What will i need to do to run EGR on this combo? (will an edelbrock intake work run EGR with these heads?
3. What screw in studs should i aim to get?
Answer what you can please.
Thanks guys (n gals if any),
Boldguy
Jorlain
Oct 8, 2015 01:57 AM
Buggy Disaster
Sep 22, 2015 01:15 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
