Springs for L98 heads
Old Jun 20, 2008 | 09:13 PM
310IROCZ's Avatar
Does anyone know if there are valve spring upgrades for L98 heads that can be installed without having to machine the heads?
Old Jun 20, 2008 | 09:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Springs for L98 heads
there are alot of good springs from mild to fairly aggressive that will fit the L98 head pockets. But doesnt do any good when the heads only handle roughly .470 lift and near .510 with offset locks/shims. By then you have to worry about the stock press in studs from pulling out.
but few examples are the Patriot gold and extreme gold springs, they should fit in the stock pockets. AFR has 8017 springs that should fit.
Manley 22410's are a great spring that will definately fit. Comp 981's are factory spec replacements. 918 beehives will fit and are a good spring too. there are 915 beehives i believe which are lower pressure/lower lift but good for most mild hydraulic roller cams
any thing up to around 1.27 inches in diameter i think will fit. stock are 1.25 and .02 isnt that much difference. AFR's 8019's are 1.29 inch and possibly so are the extreme golds, i dont have the figures on me..but both of those springs are for very aggressive hydraulic roller cams
Old Jun 20, 2008 | 09:51 PM
310IROCZ's Avatar
Thanks, I think i will put in a set of screw-in studs ,locks and shims
Old Jun 22, 2008 | 05:57 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Manley 22410-16 springs, 23652-16 +.050" retainers, and 13091-16 locks will bolt right in and let you run up to .550" lift. You should also install 42106-16 3/8" screw-in studs as well.
Old Jun 22, 2008 | 06:00 PM
310IROCZ's Avatar
Thanks thats great info. do i also need shims?
Old Jun 23, 2008 | 08:09 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
no shims- they are for worn out springs that people dont want to replace
I will get some sort of flack for that one
get some z-28 springs unless you want to be like some of the guys who have more money than research skills
Old Jun 23, 2008 | 04:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
shims are for dialing in spring pressures for the cam that will be used. if you run offset locks or retainers to raise the spring height, spring pressure falls down and may not be suitable for the cam.
Z28 springs are good for stock replacement but he said spring upgrades that fit stock heads. Z28 springs arent much of a upgrade
Old Jun 23, 2008 | 04:50 PM
tpi user's Avatar
i ran tpis springs on their zz9 cam in a stock heade l98 a few years back it had .520 lift an i didnt have to do anything to the heads bolted right on .icant remember the number but i think its on their website
Old Jun 23, 2008 | 10:42 PM
310IROCZ's Avatar
Thanks guys for the tips and advice.
Old Jun 27, 2008 | 01:16 PM
310IROCZ's Avatar
I was looking on ebay and there was a set of z-28 springs good for 550 lift can this be right?
Old Jun 27, 2008 | 05:21 PM
jamon8's Avatar
Engine: 350 tpi
if you have an aggresive roller cam that is going to rev over 5500 then you need a spring with a heavyer seat preasure
lt500r55
Sep 1, 2021 01:30 PM
mrestrictrplate
Aug 27, 2015 11:54 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
