i have tested dam near everything , now what ?
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
i have a stock l98
i have been chasing a rough idle for weeks now .
here are the symptoms .
when you first start the car it stalls, try it again it will run but it runs rough and the motor shakes the whole car . for about the first 5min of driving the car smokes , seems like oil smoke (blueish) and the exhaust smells funky . if you drive it and let it warm up it gets alot better and runs pretty good (but still has funky smelling exhaust) .
this is what i have done so far ,
checked codes - none .
tested ALL sensor's according to GM shop manual - all good .
tested fuel pressure - good .
tested plugs/wires/cap/rotor - good .
hooked up to a snap on scanner - all seemed within range (im no expert with 1 and was on limited time with it) .
used carb cleaner to check for vacuum leaks - found none .
here are things that have been replaced within the last yr .
injectors
fuel pressure regulator
IAC
CTS
EGR valve
this seemed to happen all of a sudden out of nowhere and i am running out of ideas , what would you do next ?
injectors
IAC
CTS
EGR valve
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: i have tested dam near everything , now what ?
i would check thoroughly for vacuum leaks, they can usually cause idle issues.
you mentioned that it smelled like oil... are you loosing any oil?
is the smoke coming from the exhaust, or could it be oil dripping off of somewhere and burning on something hot (maybe headers)?
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
check all of the vaccuum lines especially the (TB to EGR solenoid line) they melt first. and check for vacuum leaks around the manifold, etc. spray some starting fluid around suspected leak areas, and if/when you find it put some sensor safe rtv and let it cure for 24 hours. just a start. also try a vacuum guage and try to find it that way...
good luck and god speed
Goodfella
Goodfella
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
Goodfella
Goodfella
Car: 1987 camaro RS/Z28 clone
Engine: 305 bored .030 over
Transmission: 700r4 slippin its way home
Axle/Gears: 9 bolt 3.43 gear
so if its not oil then you are looking at fuel.
maybe you have an injector stuck open.
or at least INTERMITTENTLY
thats really the only other thing that would cause smoke.
and cause the car to run rough
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Have your cooling system pressure tested. Sounds bad, but you may have popped a head gasket. Pressure testing and checking by a good mechanic will tell you. Does the exhaust smell sorta sweet?
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Does it run ok after it warms up?I would pull the plugs anyway and look at them. Sounds like valve seals letting oil in or popped head gasket- cracked head.
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
ya it runs pretty good after it warms up . the exist does not smell sweet and i have not noticed any coolant loss .
Engine: 355
I would pull the plus and run a compression check.
If you run it with the rad cap off (starts it cold), does the coolant seem to have alot of bubbles come up? Sometimes a leaking (not blown) head gasket will not be bad enough to leak fluid, but can leak compression from the cylinder into the cooling system.
RedLeader289
May 28, 2019 01:47 PM
