454 Fires for a second and then dies... help please
Old Jun 22, 2008 | 05:04 PM
smokey454's Avatar
Hi guys,
I have a Chevy 454 in my 91 RS and it starts up and turns off after a second. My guys just put a new intake manifold and carb in and re-ran the fuel line, and replaced the rotor and distributor cap.
When I picked the car up on Friday, it ran strong enough to have me smiling the whole way home, but come Saturday night, it began with this annoying problem.
I pulled off the fuel line at the carb and there is definitely fuel there and the carb appears to be working correctly (vacuum,s etc). I assume this is a distributor problem but would really appreciate any help you guys can offer.
Old Jun 22, 2008 | 06:02 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: 454 Fires for a second and then dies... help please
is your timing right? maybe you forgot to tighten the dist. hold down.
Old Jun 22, 2008 | 07:13 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Does the carb have a choke? Is it functioning correctly? It should be almost completely closed when you snap the throttle open really quick when its cold and not running.. the choke blade should be only open about 1/8" or so. How fast does it idle for the short time it runs?
If the choke isn't set right, or isn't there at all, it will run like crap and probably stall alot when the engine is cold, but it will run just fine once its warmed up.
Old Jun 22, 2008 | 07:44 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
what happens when you hit the gas? You may need to pat the gas untill the engine warms up.
Old Jun 22, 2008 | 09:55 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Theres many ways a car can "die" and depending on what its doing, we can help you figure it out.
1) Does it run for the exact same amount of time every time, or does it vary?
2) Does it stumble and then die?
3) Does it slow down, and eventually cut out?
4) Does it "diesel" when it dies?
5) Does it sound like it missed a beat when it died? Like a back fire?
How do you start the car? How many times do you pump if you have a carb, and do you rev it when it starts?
Ive had a "car dies" problem a few times and it was always something different.
Dieing battery for example, will slowly cut out, and run on fewer and fewer cylinders until it dies.
Off timing will cause it to "miss a beat" and back fire out of the carb. (retarded).
Ive also had a "runs perfect for exactly 3 seconds and then suddenly stops". I had grounded my ignition wire, while installing my alternator bracket. It was pinched and grounded through the block.
Old Jun 23, 2008 | 04:39 PM
smokey454's Avatar
Under the hood as we speak... any immediate help is much appreciated!
The car runs for the exact same amount of time every time before it stumbles and dies. I try and rev it when it starts but it continues to do the same thing, even after I wait for a while between tries (just in case I am flooding the engine).
The carb is brand new and appears to be functioning correctly. It got me back from the shop beautifully.
86camaro383, what do you mean by tightening the distributor hold down? The 4 bolts that connect the cap to the dist?
THANKS!
Old Jun 23, 2008 | 04:47 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
More information is needed. What distributor are you running (vacuum advanced? stock distributor in Open Loop? what?) How is fuel being supplied (mechanical fuel pump? stock electric fuel pump? aftermarket pump? what?). If your running the stock fuel pump, but with an adjustable fuel pressure regulator, and/or rigged the stock distributor to run with a carb setup, it might be your VATS, and/or fuel pump cut off. You see, more information is needed....
Old Jun 23, 2008 | 08:05 PM
Air_Adam's Avatar
Once it starts, if can you feather the throttle and keep it running?
Old Jun 23, 2008 | 09:13 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
i am betting the oil pressure sending unit has crapped the bed... unplug the sensor and jump the farthest pin to the left and to the right on the connector then listen for the pump and start the car...
mine did the same exact thing on the ride home after my engine swap... fuel pump was priming the bowls but wouldnt run after the engine built oil pressure... replaced the OPSU and it blew again in a couple of weeks had to setup a relay to my ignition kill switch to run my pump
KCG
Jun 24, 2020 04:33 AM
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
