oil preassure high?
Old Jun 25, 2008 | 10:57 AM
darkcowboi's Avatar
oil preassure high?
More problems. Finally got the car running and now my oil pressure pegs out when I start the car. I havn't driven it yet for fear of blowing seals. Can anyone tell ne how high is too high? 90 RS, 305 TBI, running 20w50
Old Jun 25, 2008 | 12:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
First, I wouldn't believe the factory in-dash gage. The sending unit is prone to failure. Hook up a mechanical gage and verify what you have - or, just replace the sender and see if that changes anything.
Pegged = zero resistance. Also check any possible wire grounding (shorted) for that circuit.
And, there's no good reason for running 20W-50. That could cause high pressure when cold, but not pegging the gage. Switch it back to 10W-30, in any case.
Old Jun 25, 2008 | 12:40 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: oil preassure high?
With 20w50 oil you will peg the 60 lb gauge when you start the car, when the engine is cold. Why are you running 20w50 oil? Switch to a 5w30 oil and see how it operates. As far as causing problems the higher oil pressure will not cause any damage unless it gets over 100 PSI where it could burst the filter.
Old Jun 25, 2008 | 12:42 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Mine always seems to be pegged when the car is cold (10w40 oil). It only comes down to "normal" when it's fully warmed up.
Old Jun 25, 2008 | 06:55 PM
Guy In A 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6 MFI
Transmission: MD8 Hydra-Matic 4L60
Axle/Gears: Standard/3.23
That's good advice. . . Mine is always pegged when I first start it. . . After warming it up for a bit, and drive a mile or two, it's fine. And I only use 5W-30 or 10W-30.
Old Jun 25, 2008 | 06:57 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I run 20w50 in my car, oil pressure is 45 when cold and 30 when warm.
I am running thicker oil since I have almost 200K miles on the motor and it runs 25psi and 10psi on 10w40 oil.
Old Jun 25, 2008 | 07:01 PM
five7kid's Avatar
Let's say in a mechanically sound stock engine, there's no good reason to use 20W-50.
If you have to use it to "fix" something, it's a crutch.
Old Jun 26, 2008 | 07:42 AM
darkcowboi's Avatar
It seems to use oil when I run 10w30. Replaced the sending unit and it's now at about 45 at idle and yet again above 60 when driving
Old Jun 26, 2008 | 07:49 AM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Maybe a dumb question, but did you put too much oil in?
Old Jun 26, 2008 | 07:56 AM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
I run straight 30 weight mobile 1 , 50 psi cold 35 -40 hot . It dropped to 0 and I had a heart attack but quickly pulled myself together and realized the car was running fine so I changed the sending unit and all was fine for about 6 months when all the sudden it shot up to over 60 and it's been there for 4 months , I'll fix it at the next oil change , never completely trust the factory set-up it's just a good reference .
Old Jun 26, 2008 | 08:06 AM
Car: 1992 RS 6spd
My factory gauage reads in the red on the low side, and it has been that way since I got the car. I got a sending unit, it worked and then broke again, and it's back in the red on the low side. I agree, those guages are just a reference.
Old Jun 26, 2008 | 10:05 AM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
in my new 350 TBI im running 10-30 and i get about 45psi at idle and about 55psi while driving with my foot on the gas, in my old worn 305 before it blew, also with 10-30 i got about 30 psi at idle and about 45 psi while driving.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
