Car won't start after minor work
Old Jun 25, 2008 | 11:08 AM
489CID's Avatar
Car: 87 TA, 71 RS Camaro, 98 GMC K2500
Engine: 350 in the TA, 489 in 71,454 truck
I am working on an 87 Trans Am with the 350 TPI. The car was running rough especially around 1200-1500 RPM and was low on power so I checked a few things over, I only had 30 PSI of fuel pressure, I swapped the fuel filter and now have 50 psi. I figured I was on the right track I then changed only the distributor cap and rotor after which the car will not start. I have spark, and as I mentioned earlier I have fuel but I'm lost as to where to check next.
Last edited by 489CID; Jun 25, 2008 at 01:03 PM. Reason: Better Title and more description
Old Jun 25, 2008 | 12:21 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Help
Geez guy, edit your thread title, "HELP" does tell us squat.
You want help? Help us help you, put some detail in that ok?
Old Jun 25, 2008 | 02:09 PM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
Re: Help
Relax, thread title police. What a nice first impression.
As for your problem, I would backtrack to the cap and rotor. If it ran before that, but not after, that is quite a clue.
Old Jun 25, 2008 | 02:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
489CID, welcome aboard thirdgen.org.
Now, about editing: the thread title can only be edited by mods & admins. Which I have done. For future reference, a descriptive title is helpful. But, let's not bang on people (especially new or relatively new members) on the public forum.
Okay, to your problem: Agree, recheck the last work you did. It isn't hard to get one terminal off when putting spark plug wires on a new cap. If you can't figure it out, I'd offer to come by and take a look at it, but I really can't promise I'll be able to do that.
Old Jun 25, 2008 | 03:49 PM
489CID's Avatar
Re: Car won't start after minor work
That's it I pulled the cap and rotor twice. Rechecked everything and I''m still stuck I am going to recheck again tonight when I get home and see if there is anything I missed. I was just wondering if there was any thing I could have inadvertantly unpulgged that would have caused this.
Old Jun 25, 2008 | 05:06 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Check the plugs that go into the ignition module at the bas of the distributor. Also, triple check the firing order.
Old Jun 26, 2008 | 07:52 AM
489CID's Avatar
Problem solved, one of the wires that goes into the distributor module has a small break in itwhen the wire was in a certain position the car ran (badly) if not nothing happened.
Old Jun 26, 2008 | 03:40 PM
Toehead's Avatar
Excellent, glad to hear you found the problem.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
killer777
Aug 8, 2015 02:47 PM
