Ignition Cylinder Replacement
Car: 1986 Camaro Berlinetta
Engine: 350 Turbo
Transmission: Automatic
Axle/Gears: 4.10
Hi i broke the ignition cylinder in my 1986 Camaro Berlinetta and i cant figure out how to change it out. I already have the cylinder but its a straight column and i just cant find out how to release the old ign cylinder. Does anyone have the diagram showing me how? i would greatly appreciate it.
Thank you, John
Thank you, John
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Ignition Cylinder Replacement
If it's anything like my tilt columns and you already have the steering wheel and associated parts removed......there should be a torx bit bolt T-20ish that is screwed into the column right below the cylinder. The bolt goes through a slot on the cylinder. Remove the bolt and the cylinder will slide right out.
Engine: 350 Turbo
Axle/Gears: 4.10
I cant remove the steering wheel, would i need the puller for this?
Car: 1989 IROC-Z
Transmission: Th700R4
You need an Steering Wheel puller and a Lock Plate Depressor,
Star by removing the bolts and horn button.
Wheel puller installed and pulling.
Steering wheel removed, and the Lock Plate is showing
I built my own Lock Plate Depressor, as shown below:
Remove the locker ring
Lockplate gone. Remove all loose things, and photo to remember how it was assebled
The black bolt is for removing the ignition lock cylinder
You dont have vats so you wouldnt have the wire into the lock cylinder, Just turn the lock cylinder clockwise (i think it was) and remove it, install the newone turning it counterclock wise and insert bolt and then check to see if it turns ok.. if it does assemble everything, if not, adjust the lock cylinder.
You got more pictures from my change of the ignition lock cylinder : http://camaroirocz.net/project/ignitionlock.htm
Its in swedish but you see the pictures, hope this post help you out.
Engine: 350 Turbo
Axle/Gears: 4.10
Thank you very much ill need to get the puller and hopefully it will all be taken care of thank you once again.
Car: 1989 IROC-Z
Youre Welcome.
Do you have steering lock to ? Do it lock if you turn it when the ignition is set to LOCK ? if so you need that pusher (the tool I made myself) You can buy it to but here in Sweden it was impossible to get it..
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Great writeup and pics Theking!
Like he said you will need a steering wheel puller and a lockplate depressor. You can rent those at a local auto parts store like AutoZone or Advance Auto. Just did this about a week ago on a 92 Z. It is pretty straight forward.
Engine: 350 Turbo
Axle/Gears: 4.10
The Steering wheel isnt locked. it doesnt lock when the key isnt in it.
Car: 1989 IROC-Z
Thanks for your feedback, maybe you check my page out : http://irocz.info.se/ and leave some marks in the guestbook, (got it translated if you click the US flag on the right side at the top) Havent translated everything yet, but there is pretty much there on the english part to.
Desmare, then you maybe dont need the lock plate depressor. Just maybe.. remove the steering wheel and see if you got the lock plate there. if not just ride on, if you got, hire the tool
Engine: 350 Turbo
Axle/Gears: 4.10
I will go take a picture of it so i can show you what it looks like.
Car: 1989 IROC-Z
Re: Here are the Pictures of my steering wheel and column
The lockplate could still be behind the steering wheel I didnt see my lockplate until I removed the steering wheel, got pictures on that on the link that I posted earlier
So maybe you need them both, but if you hire them , hire them both then you got the tools at home..
Engine: 350 Turbo
Axle/Gears: 4.10
Ok thank you very much im going to go look for the pieces tomorrow and ill use your guide to help me
If i have anymore questions ill reply. Member
Car: 92RS
THIS is great. Thanks for pics to help everyone. STICKY!!!!
You got more pictures from my change of the ignition lock cylinder : http://theking.joakimweb.se/z28/proj...nitionlock.htm
Car: 1989 IROC-Z
Also I will translate my homepage to, havent got the time yet, but im translation some every evening, So every picture on my page will have its text translated to english to, for more help when VATS is present
Engine: 350 Turbo
Axle/Gears: 4.10
ok i know its been awhile but im now having an issue, i replaced the ignition cylinder myself and now the car turns on but doesnt crank over. It was working fine before i spun and broke the old ignition. Could there be some sort of a kill switch preventing me from starting the car?
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
May have improper engagement of the cam/rod that activates the ignition and starter switch deeper in the column. Some more column help is here:
https://www.thirdgen.org/forums/tech...ck#post3451256
Engine: 350 Turbo
Axle/Gears: 4.10
Ok so now after the car wouldnt turn over with the new ignition i took the cylinder back out and tried to take apart the column like naf said and im stuck now i cant get past these wireing issues, heres some pics. if anyone has a way past these please let me know.
Car: 1989 IROC-Z
To check / change the Ignition Switch you need to lower the steering wheel, you can NOT go that way down to it.
this is how you do it:
STEERING WITH TILT : US105 , STEERING NON TILT : US95
Ignition Switch is located above the steering column
Here you see some thick wires going into it.
Loosen these 2 bolts:
Lower the steering wheel (down below you see the white Ignition Switch:
The Ignition Switch is bolted with 2 STAR bolts:
Take it down and be carefull with the wire, its for the Tranny/neutral switch:
Loosen the wire from the Switch:
Install the new one / align the steel pin for engaging the switch (pin goes from the ignition lock cylinder):
new ignition switch mounted and set to right distance for engagment:
Engine: 350 Turbo
Axle/Gears: 4.10
Well i have a non tilt steering wheel will anything be different?
Car: 1989 IROC-Z
The only thing thats different is the bolt locations on the ignition switch.
I think the NON tilt is bolted on the the oposit side , but its the same place so you need to pull down the steering wheel. I have tilt so on the pictures its a tild steering column
Car: 1989 IROC-Z
Engine: 5.7L V8
Couple questions: should you remove the steering wheel to gain better access? Also, are there any tricks to removing the blue wire connectors from the switch? I had the steering wheel down and tried to do this by hand by found it very difficult. I am thinking that removing the wheel will help but the connectors seemed to be fairly stuck in there.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
11 year old thread. If you have questions you need to start your own thread in the appropriate section of the forum.
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
