wierd engine problem
Old Jun 29, 2008 | 06:25 PM
antosh's Avatar
Car: 1991 camaro z28
Engine: 5.7 TPI L98
Axle/Gears: stock
i cant seem to solve this one so i am asking all off you i have a 1991 z28 with the 350 tpi
and the problem is starts but then when i leave it in the sun for a while and it gets hot it wont start and seems to be pouring gas into the engine i have already changed the fuel regulator and checked all the fuel injectors it will start right now becasue its in my garage but when i leave it outside idk what goes on but in wont start so hopefully someone out there can help me i am willing to try anything you guys can think of.
Old Jun 29, 2008 | 06:41 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: wierd engine problem
when it doesnt start, do you have spark?
Old Jun 29, 2008 | 06:45 PM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
yes i do plus there are new sparkplugs fairly new wires and new cap
Old Jun 30, 2008 | 02:50 PM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
alright did some research on the internet for a few hours trying to see if anything would come up and i found this
it had the same symptoms as mine it would start and run fine but when it was hot it wouldnt start and was pouring gas into the engine it was said to confuse many people and the solution was that the coolent sensor was bad and when it got hot it would cause the fuel not to go into a closed loop and just let gas pour into the engine
the reason i post this is does this sound like it could be a the reason or does it sound to good to be true
Old Jun 30, 2008 | 09:44 PM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
anybody???
Old Jun 30, 2008 | 10:03 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
I suppose it sounds feasable. I had a simaliar problem with a '90 Honda Accord, Yeah I know its a different animal but. If I opened the door and let the hot air out for a few minutes it would start. Turned out the parts counter guys at the Honda dealership were all to familiar with this. The Honda had a Main Relay located under the dash board and when it got old it would warp internally, work properly in moderate temps. but close up the car and pour on some sun and it would not connect the ign. to the distributor.
Old Jul 1, 2008 | 12:53 AM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
yea i installed it today because when i went to buy the part it was only $15 so i thought why not give it a shot and till now it seems to be better the real test will come tomorrow when it sits in the hot sun because we already got the engine up to temp and it still starts fine without the smell of gas
Old Jul 3, 2008 | 10:25 PM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
still wont start after sitting in hot sun i am out of ideas
so i would love to hear any other suggestions or ideas on what it could be becasue i am stumped
Old Jul 4, 2008 | 12:37 AM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Wild story. our cars are getting old and they are telling it on us. I wonder if the gas tank vent is stopped up and is filling the engine with vapors giving the MAP sesor a false reading. I have seen charcoal canister filter on the battom stop up and the engine sucked charcoal into the intake manifold. Would be easy to check by leaving the gas cap loose while parked in the sun.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
