Is it the distributor or the starter?
Old Jun 30, 2008 | 07:37 PM
magadith's Avatar
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
I have replaced my starter, battery, negative power cable, and alternator. But still my car has a hard time starting both hot and cold. Mostly hot like if the starter is heat soaked. When its cold it will still start but it hesitates. Which should I go with first, heat wrap the exhaust pipe near the starter and put a heat shield the starter and add a new 2 gauge positive cable, or go with a distributor?
Old Jun 30, 2008 | 07:43 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Re: Is it the distributor or the starter?
Change your fuel filter, then visually check your spark plugs, check your spark should be blue, check your timing base timing should be anywhere from 6-13 degrees advanced, check your fuel pressure at the rail. try each in that order.
Old Jul 3, 2008 | 04:44 PM
magadith's Avatar
Engine: 305 4bbl
I did a bit of both theory's today. I changed my battery cables to a 2 gauge and I replaced the fuel filter also the starter solenoid because I overtightened it and the plastic broke.
Same situation though. Its like the battery isn't putting enough juice to turn the starter to turn the engine but when its cold it will start the car, a little difficult but it will start. After driving it around for a few minutes to let the engine warm up and the generator charge the battery is when the car won't start for a while. The starter can't be heat soaked because it is new and when cold it should start with ease.
Also the only time it will start up easily is when it has been started up cold, ran for a minute, shut off, then start it back up. Other then that its been a bitch.
Next I think I should have the battery tested to see if a cell has fried.
Old Jul 3, 2008 | 05:05 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Sounds like your timing is advanced to far... even when it wont start does the motor turn over fast or does it go...vrough,vrough...vroom. thats my sound of a motor only making a half a revolution.
Old Jul 3, 2008 | 05:23 PM
magadith's Avatar
Engine: 305 4bbl
It turns slowly.
Old Jul 3, 2008 | 05:25 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
yes your timing could be to far advanced... did you adjust your timing recently?
Old Jul 3, 2008 | 05:58 PM
magadith's Avatar
Engine: 305 4bbl
It was set correctly at a shop to pass smog a few months ago. Can the timing change itself since then?
Old Jul 3, 2008 | 06:24 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
Are you sure they set it correctly, Did it do this before it went to a shop?
It sounds like they advanced it to far or the distributor was installed a few teeth off and they advanced it until it ran okay.
Old Jul 3, 2008 | 07:17 PM
magadith's Avatar
Engine: 305 4bbl
They had to set it right because when I took it to get it smog, they used the timing light to make sure its correct with the mark to pass the visual inspection.
Old Jul 3, 2008 | 08:19 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
they may have not disconected the ecu timing control plug( thats what I call it anyway) do your self a favor and have your battery tested, if its not that then its your timing , theres a tech article on the home page on correctly setting the timing for these cars .
Old Jul 4, 2008 | 04:20 PM
magadith's Avatar
Engine: 305 4bbl
Problem solved.
The cells in the battery was bad for only being 6 months old. Battery was still under warranty so I got a new one. Everything is now fine.
Old Jul 5, 2008 | 10:24 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
buy the selinoid heat shield
cheap and easy
Old Jul 5, 2008 | 07:09 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
parasitic Draw?
Old Jul 5, 2008 | 11:08 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
what the hell is wrong with all you guys. He said 3 times the motor is cranking slowly. What in the world does that have anythign to do with the timing?! If you dont have a clue what youre talking about you really shouldnt say anything because you just make the situation more confusing.
megadith let this be a lesson to you that many people dont seem to understand. Just because something is new doesnt mean thats not whats broken. New parts are often defective so dont rule them out.
Also the simplest answer is usually the right one. If its not cranking hard you probably dont have enough voltage at the battery. Buy a multimeter. In the future, because i promise this will happen again, check the voltage at the battery while the car is running, should be more then 12 volts, like 13 or 14.
If its less then 12 volts then your alternator is dieing/dead
If its more then 12 volts the alternator is fine and your battery probably isnt holding its charge. Test the battery with the engine off and if the voltage is less then 12 then its the battery.
Timing too far advanced? lol wtf
Old Jul 5, 2008 | 11:13 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I think if the timing is too far advanced the spark/combustion will fight the starter and if it's way too far advanced maybe it could cause it to turn too slowly and roughly to start very easily.
Old Jul 5, 2008 | 11:16 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
if the timing was that far advanced i would have to think your motor would make some pretty unhappy freakin noises, not just turn over slow.
Old Jul 6, 2008 | 12:28 AM
Car: 1992 Camaro RS
I've heard peopel complain about this happening when they set up their distributors to have their timing locked out.
Old Jul 6, 2008 | 12:57 AM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
If the timing is to far advanced the motor will turn over slowly, Had the same problem with my car.
Old Jul 6, 2008 | 02:18 PM
Car: 91 RS
Engine: 350 vortec
very sorry to hear about that brain fart of your there doug... but maybe you have just never seen a car running 34deg of timing locked out... the engine becomes very difficult to turn over... do to the high CR and the advanced timing... so hard that normaly you take one out of the picture... since you cant do away with the CR you must kill the ignition... i have a little SPST switch that cuts power to the dist until the engine has turned over a couple of times then flip the switch and fire the engine....
SAME thing will happen to any engine that has to much base timing... even yours... dont believe me go give your dist a spin and try and fire the engine
Old Jul 6, 2008 | 10:14 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
So are you an ******* in real life or do you just play one on the internet...... Timing advanced to far will make a motor turn over slowly when hot just like he described.... if running a high octane fuel the spark knock may not be as noticable.... but Im sure you know that cause your obviously much smarter than everyone else on this thread.... lol wtf
Old Jul 6, 2008 | 11:18 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
allright allright my comments were a little more then should have been said
No ive actually never heard a motor with the timing that far off that it just hesitated turning over. I still find it hard to believe that it wouldnt be popping and doing all sorts of nasty **** that would be more then obvious.
I apologize tho my comments were offside for sure, everyone was telling him its gotta be his timing, clearly missing the more obvious solutions
Old Jul 6, 2008 | 11:21 PM
Car: 91 RS
Engine: 350 vortec
we didnt miss the obvious he had ruled the obvious out by claiming to have just replaced the battery
but yes you could advance the timing so far that it will actually kick back and cause some pretty good damage especially on the higher compression engines
Old Jul 6, 2008 | 11:24 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
just cause its new doesnt mean it wasnt ****ed.
Really its up to him to discern betwen good advice and getting sent on a wild goose chase, which luckily he did on his own
i still dont buy that a motor with way too much base would just seem hesitant, i still think it would try to start and pop and bang, but like i said ive never heard it, already apologized for my comments
EDIT: well ive been corrected, i was completly off base and should havekept my mouth shut, and was completly wrong
so i apologize, i didnt think that would be the case but clearly am wrong, no sarcasm, have had the error in my ways pointed out, so no need ot yell at me anymore lol
Old Jul 6, 2008 | 11:43 PM
Car: 91 RS
Engine: 350 vortec
but you see what i was saying was HE said he replaced the battery in an attempt to fix the slow cranking... so it was already cranking pretty slow before the new battery... and really i have never seen a new battery drop a cell so fast... i have seen them drained and just seem like they have....
i think this problem will return shortly... if it hasnt already
Old Jul 6, 2008 | 11:47 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
i havent seen it in a battery specifically but ive seen so many people replace a bunch of stuff then wonder why their car doesnt work, but assume everything new couldnt be the problem
i agree in the first post he said he replaced the battery to try and fix the already existant problem
i ASSumed that that much timing would be a little more obvious, but asked a couple friends in the know and they pointed out how wrong i was. I guess thats why they say when you assume you make an *** out of you and me
or in this case just me
Old Jul 7, 2008 | 07:50 AM
jamon8's Avatar
Engine: 350 tpi
take your car to a shop
it is obvious to me that you want us to reach across cyber space and fix it
if you dont have any money and you cant wrench leave the third gen alone
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Damon
Sep 26, 2015 04:29 PM
