Wheelie?
Old Jul 1, 2008 | 09:20 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Wheelie?
Ok i have seen some cars do some wheelies but they are making mid 300 to the rear. Now how are they doing that? I will be putting a 383 with 475 at the crank so i should have the power to do one. I just want to know how they are doing it. Im guessing like 4:56 rear ends and what ever else?
kevin
Old Jul 1, 2008 | 10:11 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Re: Wheelie?
lighten the front end as much as possible and lots of torque
Old Jul 1, 2008 | 10:17 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Re: Wheelie?
Also you will need to get some drag shocks 90/10 front and 50/50 rear, bu twhy would you want to do wheelies? Keeping the front end down and the rear planted is what makes low ETs.
Old Jul 1, 2008 | 10:57 PM
Re: Wheelie?
No i just wanted to no how their doing it with not a hole lot of power. I mean i think it would be cool to get the front off mabey 2inches. Do you think i could? I might run my car once thats a 50% chance i just want a quick car thats why im getting that motor.
thanks
kevin
Old Jul 1, 2008 | 11:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Wheelie?
Light front end, traction and lots of torque but a good chassis setup can pull the front wheels of a nose heavy car. Instant center, weight transfer, shock settings and spring rate can make a huge difference in how the car launches.
My car makes lots of power and is only slightly nose heavy. I carry the front wheels for about a car length but with less than a foot off the ground and I don't use wheelie bars. I also launch with a transbrake at 5000 rpm.
Old Jul 2, 2008 | 02:30 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Re: Wheelie?
Correct me if I'm wrong, but if there two identical cars with the same hook and one lifts the front end 2 feet and carries them to the 60 foot line, and one that doesn't lift at all, won't the one that doesn't lift be quicker?
Old Jul 2, 2008 | 08:20 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Wheelie?
Normally. You want all the energy to push the car forward not upward. Getting the car to lift will help if you need the extra weight over the wheels for traction.
Old Jul 2, 2008 | 10:00 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Wheelie?
That's right. If your wheels are only a few inches off the ground, then you know all 3400lbs or whatever, is on the rear wheels. Hard to break traction once you've got the wheelie going on.
But if you can keep traction with all 4 on the ground, you'll have more energy to go forward with.
oh yea, drag slicks are pretty important for this too
Old Jul 2, 2008 | 10:16 AM
squeeezer's Avatar
Car: 5 cars
Re: Wheelie?
no body has said transbrake and high stall converter yet????
Old Jul 2, 2008 | 10:33 AM
RaGiN Z's Avatar
Car: 83 Camaro
Engine: 383 stroker, mini blower, nitrous
Transmission: TKO600
Re: Wheelie?
you didn't read the whole post.
Old Jul 2, 2008 | 12:08 PM
squeeezer's Avatar
Car: 5 cars
Re: Wheelie?
ahhhhh..........................duelly noted!!!!
Old Jul 2, 2008 | 07:11 PM
Re: Wheelie?
I would of dreamed of my car doing a wheelie but it sounds like its not to hard. I think it would be sweet to be at a stoplight and pick the front up 5 or 6 inches.
thanks
kevin
Old Jul 2, 2008 | 08:18 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: Wheelie?
you are gonna have trouble doin it in the street, almost impossible.
Old Jul 2, 2008 | 09:12 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Axle/Gears: 3.55
Re: Wheelie?
ive seen a 13.6 sec mustang pull the tires at least 6 " but it was still only a 13.6.
you deff want to tune the car to go forward as fast as possible. you need to tune it to loose traction and black track the tires. not smoke. then send a little more weight to the rear. to keep the tires planted. thats as good as your gona get.
Old Jul 2, 2008 | 09:51 PM
DIGGLER's Avatar
Re: Wheelie?
with no front suspension limiters, my car picks the fronts up 6" or so and carries them 6 feet or so on motor. 1.55 60'. ~368rwhp
with a 135 shot it picks them up 2-3 feet and carries them 50-60 feet. 1.32 60'. ~425rwhp
3.90 gear, th400, 3050lbs, 28x10.5 slicks, stock type suspension, leaving off the foot brake around 1800 rpms.
Old Jul 3, 2008 | 12:31 AM
Sonix's Avatar
Car: 1982 Trans-Am
Re: Wheelie?
Yea, not going to happen on the streets though roads aren't perfect enough, and you can't put drag slicks on the street.
There was a late '60's AMC in car craft once upon a time that had pictures of him doing a wheelie on the street, at a stoplight. They didn't actually post those pictures because it's so illegal, but they admitted he was right, it was possible.
Old Jul 3, 2008 | 02:08 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Re: Wheelie?
You deserve whatever is coming to you..
Old Jul 3, 2008 | 09:21 AM
Re: Wheelie?
I never was thinking my car could ever be possible to do a wheelie. But their is no way you can say that it wouldnt be cool if you was gona race someone or something at a street light and you pull the wheels.
kevin
Old Jul 3, 2008 | 09:41 AM
Stephen's Avatar
Car: 87 GTA
Re: Wheelie?
It's all about weight distribution...When I young & stupid, my old '65 VW Bug pulled the front tires REGULARLY on it's skinny street tires, on the street.
Old Jul 3, 2008 | 03:45 PM
Car: '72 Chevy Nova
Transmission: TH350
Re: Wheelie?
kevin
Cool looking maybe, highly improbable of happening on the street, but dangerous definitely.
Old Jul 3, 2008 | 05:35 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
Re: Wheelie?
i think someones been watching a little to much fast n furious
slicks would help quite a bit, maybe you should look into some cheater slicks which are barely legal but you can mount and drive with them i know MT makes em.
and why use a transbrake? takes the fun outta it.
Old Jul 3, 2008 | 06:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Re: Wheelie?
i was thinking the same, either way, it was a cool launch
Old Jul 4, 2008 | 09:59 AM
Re: Wheelie?
If that movie never came out my life would of been alot better! Now everyone wants them stupid cars and i cant stand it.
kevin
Old Jul 4, 2008 | 06:27 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
Re: Wheelie?
i will be running 28x12.5 et streets on mine. but it proably still wont wheelie on the street casue ill have the boost down and proably wont be leaving on the brakke.lol
Old Jul 4, 2008 | 09:23 PM
AsphaltAssalter's Avatar
Car: 92 Camaro
Re: Wheelie?
My 10HP Snapper riding mower will pull the front tires, on grass even
Old Jul 5, 2008 | 07:01 AM
squeeezer's Avatar
Car: 5 cars
Re: Wheelie?
yeah my cub cadet too
sad ...............only thing in my garage that can
Old Jul 9, 2008 | 08:13 PM
85blownLt1's Avatar
Car: 85 Trans Am
Engine: 305 (Building 350)
Axle/Gears: Stock
Re: Wheelie?
Suspension tuning, slicks and a very high rear end gear will make you do a wheelie. Please dont try to do this on the street.
overdriv
Aug 20, 2015 03:52 PM
Iroc Adio
Oct 27, 2008 01:19 AM
AlkyIROC
Oct 16, 2005 11:01 PM
caribbean 85
Jul 9, 2005 07:36 PM
One Eyed Jack
Theoretical and Street Racing
33
Jul 8, 2001 11:01 PM
