Question about TPI and engine combination
Old Jul 3, 2008 | 08:13 AM
69-Camaro's Avatar
HI,
Just wondering if a TPI intake would work on a 1985 engine out of a 1500 series pickup? I will try to get the numbers.
Old Jul 3, 2008 | 03:46 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Re: Question about TPI and engine combination
As far as it being an 85 block, there's no problem there.
Old Jul 6, 2008 | 12:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
'85 engines have perimeter bolt valve covers, with the older style intake manifold bolt pattern (all bolts are at a 90-degree angle). You will want either an 85-86 TPI intake manifold, or any aftermarket TPI intake such as from Edelbrock. If you get an 87-92 stock tpi intake, you will need to elongate the middle four bolt holes from the newer 72-degree angle to the older 90-degree angle.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
cRoe4
Aug 7, 2015 08:46 PM
