can someone show me a rocker arm install guide?
Old Jul 6, 2008 | 03:19 PM
regal1975's Avatar
Car: 1984 T/A
Engine: 327
Axle/Gears: 3.23:1
I am looking for a detailed and easy to follow
guide for putting in stock style stamped rockers.
thanks!
Old Jul 6, 2008 | 03:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: can someone show me a rocker arm install guide?
1. Install rockers.
2. Lash valves.
Old Jul 6, 2008 | 03:31 PM
regal1975's Avatar
Car: 1984 T/A
Engine: 327
Axle/Gears: 3.23:1
2 quick questions..
on step 1, how do you do that?
and also,
on step 2, how do you do that?
thanks
Old Jul 6, 2008 | 04:57 PM
regal1975's Avatar
Car: 1984 T/A
Engine: 327
Axle/Gears: 3.23:1
I found a basic guide in a chiltons manual, but it is for a motor with a balancer. This motor has no balancer (internally balanced) and as such, I cannot line up any marks to determine tdc. I cannot spin it fast enough by hand to build up any real pressure either.. is there another method?
Old Jul 6, 2008 | 05:04 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
1. Pull the valve covers off. I believe it's about a 9/16 socket to remove the old rocker arms.
2. After you have those pulled off, put the new ones on. (don't forget assembly lube on pushrods and valve stem tips)
3. Install rocker *****. (again assembly lube)
4. Put on the nuts.
5. Start the long process of adjusting valve lash. (FOR HYDRAULIC LIFTERS)
A) Start from the beginning with #1 cylinder. Turn engine over until the pushrod for the exhaust is up.
B) Tighten the intake rocker nut until the rocker just about touches the pushrod.
C) Slowly tighten nut while rotating the pushrod between two fingers, when you feel a bit of resistance while spinning the rod. STOP
D) Give the nut an extra 1/2 turn for hydraulic lifters.
E) Turn over until intake is up and exhaust is down.
F) Repeat B-D
G) Repeat for each cylinder.
You might want to pull the plugs or you'll have a fun time trying to turn it over.
If you are installing a new cam, you might need to give a bit more than 1/2 turn to account for cam/lifter break in.
This is what I did on my engine with roller rockers. I have not got it in the car yet, so if I am wrong in any little way please let me know.
Old Jul 6, 2008 | 05:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, it does.
TZFBird's method of lashing the valves will work. Do a seach for "valve lash" and you'll turn up at least half a dozen other methods.
Old Jul 6, 2008 | 09:17 PM
regal1975's Avatar
Car: 1984 T/A
Engine: 327
Axle/Gears: 3.23:1
think i got it right..
and unless you are speaking of the weights on the flywheel, then you are incorrect.. the motor has no harmonic dampener/balancer in the way that most motors have.. the crank pulley bolts pretty much directly to the crank.. the motor has run for 3 years that i know of with no harmonic balancer, the factory timing cover has the timing tabs located about 2" from the crank itself (unless perhaps it had a 4" balancer factory), the flywheel is weighted, and there is a balance shaft-like device installed from the factory..
if i am missing things, please let me know... just going by what i see, not trying to **** anyone off.
Old Jul 6, 2008 | 09:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Post a picture of it if you can, because what you describe is most definitely not a small block chevy.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
IROCZ1989
Aug 19, 2015 08:15 AM
mdtoren
Aug 16, 2015 05:45 PM
