Some extra cash... WWYD?
Old Jul 6, 2008 | 07:14 PM
Jeff Dizzle's Avatar
Car: 1984 Firebird SE
I have a stock '84 Firebird SE, 305, auto, and there's a good chance I'm selling my old car soon and will have some extra money. The car is in good condition, inside and out. If you had $750, give or take a hundred or so, what would you get? A few small things, or put it all into one? I'm leaning towards a full exhaust setup, but the suspension could use an upgrade too... Anyways, give me some ideas!
Old Jul 6, 2008 | 08:07 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: Some extra cash... WWYD?
if you are going for a blend of pleasure and performance, i would go exhaust.
if you are going for comfort or better traction, do suspension.
Old Jul 6, 2008 | 08:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
subframe connectors and a steering brace should be first on the list, all 3rd gens need them.
Old Jul 6, 2008 | 08:31 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
full exhaust setup what i would do
Old Jul 6, 2008 | 08:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you will see more change in the car with the SFC and wonderbar than an exhaust will do on a 305. but if you are looking for sound, then exhaust is the way to go. hooker 2055's and a 3" catback, probably eating up most of the budget.
Old Jul 7, 2008 | 07:35 AM
Yeah, I think I'm leaning towards the exhaust. I may have to go for the manual tranny swap after that though. A small piece of me dies every time I don't get to shift...
I'll look into the subframe connectors and steering brace. Does Summit carry them? I have their catalog and can't seem to find any. Their website seems to be blocked on the computer I'm on right now.
Old Jul 7, 2008 | 08:26 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
will someone listen to it when it is said by someone other than me
Old Jul 7, 2008 | 10:32 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
+1
At least get the steering braces to save yourself from having the steering box rip off of the subframe.
Old Jul 7, 2008 | 10:46 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I did suspension first. It even feels like it's going faster because of the way it handles. However, I can't disagree with the SFC's...I just can't find a shop that will do them.
Old Jul 7, 2008 | 11:17 AM
impaled's Avatar
i definietly agree w/ the subframes (in my first post i considered them under the suspension catagory).
i would maybe do a little of both (suspension and exhaust) on a limited budget.
aftermarket cat-back for a little bit of volume. i would go 3". you could easily do headers and y pipe later on. ($300 to way over budget)
and definitely shocks and struts.
if you want some good versitility, i would get some adjustable shocks and struts (i had the kyb agx adjustables on the mustang before i upgraded and i thought they were great for the money (~$350) on ebay).
if you want to focus on launch and drag racing, i would go for lakewood 90/10's (or 70/30's if you want it a little more street friendly) and 50/50's in back (i have the 90/10's and 50/50's).
maybe springs depending on your goals for the car (however i would consider the difficulty level higher than the shocks and struts and exhaust).
if you want it to be more of a corner carver or for asthetics, i would go for some lowering springs (i have the prokit on the stang and love them and i know they are popular for thirdgens).
if you are going for more of a drag racing usage, i wouldnt mess with the springs right now (for the cost to benefit ratio and streetability). i have the moroso trick 220 in/lb's in the front on the camaro.
Old Jul 7, 2008 | 11:36 AM
impaled's Avatar
i have heard that Competition Engineering is decent for the price. definitely get weld on. i would estimate ~$50 to 80 for getting them welded on.
http://store.summitracing.com/egnsea...2&autoview=sku
Old Jul 7, 2008 | 12:17 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I would look at getting Sub Frame Connectors from one of our sponsors before going to summit. Spohn sells a great set that just about everyone is extremely happy with. Spohn Performance
Old Jul 7, 2008 | 12:19 PM
Toehead's Avatar
IIRC those require some serious floorpan mods to fit.
RS Reaper
Oct 17, 2018 07:52 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
mattcanty
Oct 12, 2015 11:08 AM
Night rider327
Oct 9, 2015 09:25 AM
loud91rs
Oct 5, 2015 10:05 PM
