The Final Ruleing on Valve Stem Seals
Old Jul 10, 2008 | 08:16 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
In case you don’t know Valve stem seals keep oil from dripping down the valve and burning in the engine which creates a blue smoke at startup.
As of right now I am building a 355. The 350 That this head is off had probably less then 100k miles. The bearings show no wear on this block so this is a well maintained and well running engine. The spring that is taken off is the first time it has been taken off and Reveals the valve stem seal (what’s left of it). This was an average seal that was on both heads. I watch a lot of camaros/firebird on youtube and Notice that they all smoke. This may provide some incite as to why.
Old Jul 10, 2008 | 11:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: The Final Ruleing on Valve Stem Seals
Yup, they always look like that. Using just the O ring seals is a waste of time anyway. If you're doing to do the job, you may as well install positive seals.
Old Jul 12, 2008 | 09:14 AM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
There are positive seals already in place for many of them. What is the answer to this problem of smoking on start up?
Old Jul 12, 2008 | 10:44 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
move the valve down about a 3/8 and grab the base of the valve and wiggle
no matter what seal you put on them if the guide needs to be knurlled
you know what!!!!!
take them to the machine shop
Old Jul 12, 2008 | 12:26 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
I like the way this man thinks
Old Jul 12, 2008 | 01:44 PM
ls six's Avatar
I wouldnt knurl the guides unless the motor is simply going to be a runner.
If any type of performance and a long life is expected from this motor then new guides are a must.
Old Jul 12, 2008 | 02:38 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Knurling is a bad idea.
Old Jul 12, 2008 | 09:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Use aftermarket replacement seals and it'll be fine. It's not likely the guides are worn, considering that with bad seals they've had too much lubrication.
Old Jul 13, 2008 | 08:15 PM
ls six's Avatar
LOL good point^
This is somthing I need to get around to.
Old Jul 13, 2008 | 11:44 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
This is what I was thinking. What aftermarket would you prefer?
Old Jul 14, 2008 | 12:06 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you're keeping the valve guide bosses the same diameter as stock, Fel-Pro SS72527. They're listed as intake valve stem seals, but get 2 sets and use them on the exhaust, too.
Old Jul 14, 2008 | 02:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A well-done knurling job has advantages over guide replacement.
Old Jul 14, 2008 | 02:41 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
what are umbrella style valve stem seals? and are they better or worse than OEM?
Old Jul 14, 2008 | 04:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
An umbrella seal is a little plastic cup that rides up and down on the valvestem and keeps oil from dripping on the valve guide boss like an umbrella. They're not as good as positive seals that fit tightly on the valveguide boss.
Old Jul 15, 2008 | 10:36 AM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
I would like to know what they are, please.
Old Jul 15, 2008 | 01:08 PM
Car: 1992 RS 6spd
I just bought new heads like a couple weeks ago, and they have umbrella style, can I swap to the ones you suggested?
Old Jul 15, 2008 | 08:04 PM
five7kid's Avatar
Knurling work-hardens the guide.
Knurling reduces the surface area the valve stem is rubbing against (roller tip rockers are of benefit here to reduce the side-load on the valve stem).
Knurling improves the oiling of the guides/stems (for the little bit of oil that you want to let down there).
Old Jul 15, 2008 | 08:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You should be able to easily.
Old Jul 15, 2008 | 08:55 PM
black89ws6's Avatar
I never thought of it that way. I was always under the impression that knurling was what you had done when too cheap to do it the right way...but the things you listed there all make sense.
Old Jul 15, 2008 | 09:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I wouldn't want to knurl the guides on a head that's going to see street mileage with stock rockers, but on a racing head it's fine.
Old Jul 15, 2008 | 09:28 PM
black89ws6's Avatar
So, then for a regular, street driven engine, my original impression would be correct? That is, to say that it is done when one is too cheap to do it the right?
Old Jul 15, 2008 | 10:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't know that you'd find knurling to be that much less expensive than new valveguides.
Old Jul 15, 2008 | 10:26 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
https://www.thirdgen.org/forums/engi...need-some.html
Last post.
Old Jul 16, 2008 | 12:44 PM
jamon8's Avatar
Engine: 350 tpi
everyone that is interested in knurling
go to your machine shop and talk to them
its like asking your mom how to scratch your *****
Old Jul 16, 2008 | 08:48 PM
ls six's Avatar
That might have some truth to it.
That also increases the load on the remaining area causing accelerated wear.
Roller rockers are a bandaid solution and an expensive one at that since cheap roller rockers typicaly dont roll under significant load.
High quality valve guids will do all the above better and more reliably. Oiling isnt a problem so saying knurling improves it is bull. Thats just what your corner cutting shop tells you to convince you to pay to much for a job they can do faster and cheaper with a better profit margin.
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
gixxer92
Sep 1, 2015 04:32 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
