Oil pressure spikes high
Old Jul 18, 2008 | 02:51 PM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
My oil pressure spikes high (45-55) but only briefly when accelerating around the 1250-1750 RPM range, then levels off back to normal (around 30).
I am not running hot or anything, and other than that everything seems fine.
The needles flickers a lot on the way up so I am thinking it is maybe the gauge itself rather than the actual oil pressure....
Any ideas?
(I did search for this but all I found was threads on LOW oil pressure or CONSISTANTLY high pressure)
**stock 92 RS TBI 5.0, Auto**
Old Jul 18, 2008 | 02:59 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Oil pressure spikes high
most likely a bad sending unit or the gauge itself, for piece of mind you could check it with a mechanical guage.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
